Which Unit Is Not a Basic Quantity in Mechanics?
The discussion centers on identifying which unit is not a basic quantity in mechanics from a given list. Participants analyze options including second, slug, kilogram, meter, and pound. It is noted that the pound can represent both force and mass, while the slug is strictly a unit of mass. Ultimately, the consensus leans towards the pound being the answer, as it is not consistently a basic quantity in mechanics. The conclusion is that the pound is the correct choice for the unit that does not qualify as a basic quantity.
Tiven white
All the following are units of basic quantities except ______.
Select one:
a. second
b. slug
c. kilogram
d. meter
e. pound
i have eliminated the answers a, c,d i now the answer is between pound and a slug on wiki i see both being a measurement of mass so am not sure between the two though i think the slug is the answer
Select one:
a. second
b. slug
c. kilogram
d. meter
e. pound
Pound is a unit of force (except in the english system were it is sometimes a unit of force and sometimes a unit of mass). Slug is a unit of mass.
So what would u say is the answer
pounds.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
