Engineering Basic RC Circuit but with parallel switch?
The discussion centers on analyzing an RC circuit with a parallel switch, focusing on determining the current ix when the switch opens after being closed. The user seeks to find the initial voltage v(0) across the capacitor while the switch is closed, questioning the circuit's behavior at that moment. It is clarified that with a perfect switch, the current from a 4mA source flows entirely through the switch, resulting in no voltage across the capacitor or resistor. Upon opening the switch, the current will charge the capacitor, eventually leading to current flowing through the resistor. The conversation highlights the importance of understanding ideal circuit behavior versus real-life scenarios.
anthonuc
I want to find ix in the circuit below when the switch opens at t=0 after having been closed for a long time.
v(t) = v(infinity) + (v(0)-v(infinity))e-t/RC
i(t) = C dv(t)/dt
ix = isource - i(t)
v(t) = voltage across capacitor
i(t) = current through capacitor
I just need to find v(t) then i(t) then ix using the equations I have.
I transformed the circuit so that the current source and resistor in parallel become a voltage source and resistor in parallel. The voltage source = 4mA * 2kOhm = 8 V
v(infinity) = 8V
My only real problem:
v(0) = ?
When the switch is closed, how is the circuit affected? Seems so trivial but I'm really confused as to what happens to the circuit at t=0 and finding v(0).
When the switch opens it's easy - a simple RC circuit. But I'm having a hard time understanding what happens to the circuit while the switch is closed. My guess is all the current goes through the short closed switch and v(inifinity) = 0?
[PLAIN]http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs399.ash2/67756_10150101801434992_712009991_7559768_7479272_n.jpg
Assuming a perfect switch with no contact resistance, the 4mA current will all go into the switch.
So, there is no voltage across the capacitor or the resistor.
When you open the switch, all the current will go into the capacitor, building up a voltage and hence feeding some current into the resistor. Eventually all the current will go into the resistor.
Ah thanks for the reply. Current taking the path of least resistance? I've been told not to believe it as it's not actually true but maybe that pertains to real life and not ideal circuits for problems i guess. Anyway thanks again!
