How do you solve for secant with given cotangent and cosecant?
  • Thread starter Thread starter e^(i Pi)+1=0
    Test Trig
To find secant given cotangent and cosecant values, one approach involves using trigonometric identities and the Pythagorean theorem. With cotangent at -12/5 and cosecant negative, the correct triangle dimensions lead to sin = -5/13 and cos = 12/13, yielding sec = 13/12. An alternative method is to visualize the triangle based on the cotangent ratio, which simplifies the process. Additionally, determining the sign of a square root in trigonometric identities depends on the context provided in the problem. Understanding these concepts can aid in solving similar problems effectively.
e^(i Pi)+1=0
Given that cot \theta = -12/5 and csc \theta < 0, find sec\theta.
This was a question on a test that I drew a blank on, and I'm still not sure how to handle it due to my "teacher" repeatedly dismissing me when I try asking about it. Now, it occurred to me that this could be solved using trig identities and substitution. Starting with sin^{2}\theta + cos^{2}\theta = 1 and sin/cos = -5/12, I ended up with -
sin = -5/13
cos= 12/13
tan= -5/12
sec= 13/12
and I am confident this is the right answer. But, we have not covered trig identities in class so I am sure there is another easier way to solve this. My question is...what is it? Also, say you take the square root of a trig identity in an equation - how do you know weather it is positive or negative? Thanks in advance.
hi e^(i Pi)+1=0! :smile:
e^(i Pi)+1=0 said:
… we have not covered trig identities in class so I am sure there is another easier way to solve this. My question is...what is it?
that is the way :smile:
(though it would be easier to memorise and use sec2 = tan2 + 1, csc2 = cot2 + 1 :wink:)
(another way of course is to say that if cot = 12/5, then it's obviously a 5,12,13 triangle, and then eg sec will be hyp/adj)
you need to be told (as in this question)
btw, i can't see any latex :redface: … are other people having this problem?​
This was a question on a test that I drew a blank on, and I'm still not sure how to handle it due to my "teacher" repeatedly dismissing me when I try asking about it. Now, it occurred to me that this could be solved using trig identities and substitution. Starting with sin^{2}\theta + cos^{2}\theta = 1 and sin/cos = -12/5, I ended up with -
sin = -12/13
cos= 5/13
tan= -5/12
csc= -13/12
Even if you haven't covered sin^{2}\theta + cos^{2}\theta = 1 formally, I guess you could envisage a right-angled triangle with adjacent 12 and opposite 5, and get the hypotenuse with Pythagoras, for one.
Sometimes I don't see latex, but it always pops up after I refresh. Thank you for the quick responses.
edit - actually, my answer WAS wrong since I started with tan = -12/5 when it was -5/12, but it's fixed now.
