How Does Bayesian Estimation Determine Point Estimates with Prior Distributions?
rayge
Let Y_n be the nth order statistic of a random sample of size n from a distribution with pdf f(x|\theta)=1/\theta from 0 to \theta, zero elsewhere. Take the loss function to be L(\theta, \delta(y))=[\theta-\delta(y_n)]^2. Let \theta be an observed value of the random variable \Theta, which has the prior pdf h(\theta)=\frac{\beta \alpha^\beta} {\theta^{\beta + 1}}, \alpha < \theta < \infty, zero elsewhere, with \alpha > 0, \beta > 0. Find the Bayes solution \delta(y_n) for a point estimate of \theta.
The attempt at a solution
I've found that the conditional pdf of Y_n given \theta is:
\frac{n y_n^{n-1}}{\theta^n}
which allows us to find the posterior k(\theta|y_n) by finding what it's proportional to:
k(\theta|y_n) \propto \frac{n y_n^{n-1}}{\theta^n}\frac{\beta \alpha^\beta}{\theta^{\beta + 1}}
Where I'm sketchy is that apparently we can just remove all terms not having to do with theta, come up with a fudge factor to make the distribution integrate to 1 over its support, and call it good. I end up with:
\frac{1}{\theta^{n+\beta}}
When I integrate from \alpha to \infty, and solve for the fudge factor, I get (n+\beta)\alpha^{n+\beta} as the scaling factor, so for my posterior I get:
(n+\beta)\alpha^{n+\beta}\frac{1}{\theta^{n+\beta}}
Which doesn't even have a y_n term in it. Weird.
When I find the expected value of \theta with this distribution, I get 1. Which isn't a very compelling point estimate. So I think I missed a y_n somewhere but I don't know where. Any thoughts? Thanks in advance.
Not an area I'm familiar with, so can't help with your specific question, but one thing does look wrong to me: if you substitute n=0 in your answer, shouldn't you get h(θ)? The power of theta seems to be one off.
I wrote a whole reply here while totally missing what you were saying. Thanks for the response! I'll check it out.
I'm not sure how the loss-function business enters into the calculation, but you seem to be trying to compute the Bayesian posterior density of ##\theta##, given ##Y_n = y_n##. You have made an error in that. Below, I will use ##Y,y## instead of ##Y_n,y_n##, ##C,c## instead of ##\Theta, \theta## and ##a,b## instead of ##\alpha, \beta##---just to make typing easier.
Using the given prior density, the joint density of ##(y,c)## is
f_{Y,C}(y,c) = \frac{b a^b}{c^{b+1}} \frac{n y^{n-1}}{c^n}, 0 < y < c, a < c < \infty
The (prior) density of ##Y## is ##f_Y(y) = \int f_{Y,C}(y,c) \, dc##, but you need to be careful about integration limits. For ##0 < y < a## we have
f_Y(y) = \int_{c=a}^{\infty} f_{Y,C}(y,c) \, dc <br /> = \frac{n b y^{n-1}}{a^n (b+n)}, \; 0 &lt; y &lt; a For ##y > a## we have
f_Y(y) = \int_{c=y}^{\infty} f_{Y,C}(y,c) \, dc <br /> = \frac{n b a^b}{y^{b+1}(b+n)}, \: y &gt; a Thus, the posterior density of ##C## will depend on ##y##, since the denominator in ##f(c|y) = f_{Y,C}(y,c)/f_Y(y)## has two different forms for ##y < a## and ##y > a##.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
