Understanding Beam Deflection: Theory, History, and Formulas Explained
In summary, The theory and history of beam deflection can be traced back to Galileo, who made the first recorded attempt at explaining it. However, it was Euler who formulated the commonly used "engineer's beam theory" and Timoshenko who added refinements to it in the 1920s, resulting in the name "Euler-Timoshenko beam theory".
mlog
Hey guys so I've been looking everywhere on the internet, and i can't find any theory and history on beam deflection. I understand the formulas and all but what is the theory behind it, who discovered the first rational answer to explain things etc..
Please Help
Galileo probably made the first recorded attempt at a theory of beams, but he got it wrong (he assumed the shear stress was constant across the cross section of the beam, which isn't correct).
Euler formulated what is usually called "engineer's beam theory" (curvature is proportional to bending moment, etc), and Timoshenko added some refinements to it in about 1920 - hence the name "Euler-Timoshenko beam theory"
What is beam deflection?
Beam deflection is the deformation or bending of a structural beam under the influence of external forces. It is a key factor in the design and analysis of structures and is essential in ensuring their safety and stability.
What is the theory behind beam deflection?
Beam deflection is based on the principles of mechanics, specifically the laws of equilibrium and deformation. It is also influenced by material properties such as stiffness, strength, and elasticity, as well as the geometry and support conditions of the beam.
Can you provide a brief history of beam deflection?
The study of beam deflection dates back to ancient civilizations, where structures such as bridges and aqueducts were built using trial-and-error methods. In the 17th century, Galileo Galilei and Robert Hooke made significant contributions to the understanding of beam deflection. In the 19th century, scientists such as Augustin-Jean Fresnel and Józef Stefan developed mathematical formulas to calculate beam deflection, leading to more precise and efficient structural designs.
What are the common formulas used for calculating beam deflection?
The most commonly used formulas for calculating beam deflection are the Euler-Bernoulli beam equation, the Timoshenko beam equation, and the moment-area method. These formulas take into account factors such as the beam's length, load, support conditions, and material properties.
Why is understanding beam deflection important for engineers and architects?
Understanding beam deflection is crucial for engineers and architects as it allows them to design safe and efficient structures. It helps them determine the appropriate size, shape, and material for a beam based on the expected loads and support conditions. It also allows them to predict the behavior and potential failure points of a structure, ensuring its stability and longevity.
11K
  • Mechanical Engineering
  • General Engineering
