Calculating 2 Sine Wave Frequencies from Beats Data
  • Thread starter Thread starter dwanty
    Calculation
The discussion focuses on calculating the frequencies of two sine waves from a dataset representing a wave over 300 milliseconds. The user has values for each millisecond, indicating that the wave is generated by the combination of two sine waves. A relevant trigonometric identity for the sum of sine functions is suggested as a potential solution. The identity can help in decomposing the wave data to extract the individual frequencies. This approach aims to solve the problem of identifying the underlying sine wave frequencies from the given data.
dwanty
1. Homework Statement [/b)
i have data from 1 to 300 ms ,for every ms i have value eg(for 1 ms=1.7665849,for 2ms = 0.2345674 and so on till 300 ms) when u draw it,it shows a wave ,which is generated by 2 sine wave and i want to calculate these 2 frequencies of sine waves from the given wave...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
