Beauty of old electrical and measuring things, etc.
The forum discussion centers around the appreciation and restoration of vintage electrical devices and measuring instruments, particularly from the early 20th century. Participants share insights on specific components like knob and tube wiring, HP 651A Test Oscillator, and various antique light switches. The conversation highlights the beauty and craftsmanship of these devices, with members expressing nostalgia and sharing personal stories related to their collections. The discussion encourages others to contribute their own vintage finds, fostering a community of enthusiasts.
  • Understanding of vintage electrical components, specifically knob and tube wiring.
  • Familiarity with the HP 651A Test Oscillator and its applications.
  • Knowledge of thermocouples, particularly Type J thermocouples.
  • Basic skills in restoring and maintaining vintage electrical devices.
  • Research the history and applications of knob and tube wiring.
  • Learn about the specifications and usage of the HP 651A Test Oscillator.
  • Explore the principles of thermocouples and their calibration methods.
  • Investigate restoration techniques for vintage electrical devices and components.
Electronics enthusiasts, vintage collectors, restoration hobbyists, and anyone interested in the history and craftsmanship of early electrical devices.
  • #241
Bystander said:
Oh? 'Nother one? Like me?
Really? I didn't know that. Care to give a town?
Edit: Never mind. Just saw Boot Hill on you profile. Now I know. :)
  • #242
jim hardy said:
Reckpn somebody took them out so they wouldn't leak and corrode ? I was surprised to see them still in gmax's meter. He must live someplace dry...
dlgoff said:
Me too. And they look in such good condition that they might still have some charge. :olduhh:
I'm in Connecticut. So it is dry. Not bone dry like the desert southwest, but al lot drier than south Florida or New Orleans. I checked the battery voltage and two of them read close to 1 volt while the third doesn't read anything. They are marked 4.5 volts.
  • #243
dlgoff said:
Awesome. I'm a KU grad. Rock Chalk Jayhawk. :devil:
[...] Nice to have another Kansan PF member. You, @Evo, and myself are the only ones that I know of.
Regards
I've spent a bit of time there.
  • #244
PM me if there's anything I can help you with in your studies, etc. Nice to have another Kansan PF member. You, @Evo, and myself are the only ones that I know of.
Hey I will keep that in mind. I've been struggling quite a bit (mostly due to time constraints), however I think I'll end the semester with an A and two B's which isn't bad for the work schedule. I'm curious as to where you got the knobs? Did you take them from old places or do they still manufacture them? Usually they get pretty torn up when demoing.
  • #245
Great grades. :approve:
I took these out of my parents old house. Also the nails are the originals from these insulators. It took some effort to not damage them when removing, as those nails had been in some really old and hard wood. Here's another look at them.
Edit: Note that I've added the Swiviller socket that has an old carbon filament medical bulb.
  • #246
Motor turned up in my LinkedIn feed
77yE41y87UNCVordEGXyD3u0qYrdfyLrLJSMfLuluVhFcSUclAZke_KhFTCwD5u8LojtdNQg2JXlJ427dA4BYBI3iSdF_NQ8.jpg
Crypto Works Co Ltd of London. Machine no 5568, 65 volt, 4.5 amps, 2200 rpm. I (the Linked in OP) believe this motor was made between 1904 and when the company went out of production in 1909.
  • 77yE41y87UNCVordEGXyD3u0qYrdfyLrLJSMfLuluVhFcSUclAZke_KhFTCwD5u8LojtdNQg2JXlJ427dA4BYBI3iSdF_NQ8.jpg
  • #247
Now that's a motor. I wonder if it could be made to run again? Here's a "ad" I found from https://www.gracesguide.co.uk/:
Thanks for sharing @Windadct .
  • #248
dont you just love the old machines - you can actually see how the field flux flows around that one !
  • #249
You should make a gravity fed mercury vacuum pump, I forget who invented it, I think it was Edison but I don't remember. If you want to make it go here . That guy is named cody he has a youtube channel called codys lab and he usually does diy stuff and general education things on his channel. The pump is called a Sprengel Vacuum pump and I think it is really cool. You should modify the design so that the mercury pours itself to make the vacuum. Also do you guys know if you could use a safer material for it?
  • #250
stephenkohnle53 said:
You should make a gravity fed mercury vacuum pump, ...
A better option than the Sprengel pump is the diffusion pump.
from https://www.tungsten.com/tips/diffusion-pumps/
In the early days, diffusion pumps used mercury as the operating fluid. As you might imagine, such a thing would be frowned upon today due to the toxicity of mercury vapors. Today, the use of mercury in diffusion pumps is essentially zero.
I forget who invented it, ...
Hermann Sprengel is credited for inventing the Sprengel pump.
Wolfgang Max Paul Gaede is credited for inventing the mercury diffusion pump in 1913.
... do you guys know if you could use a safer material ...
Silicon oil is used today in diffusion pumps. See https://www.tungsten.com/tips/diffusion-pumps/ for how they work.
  • #251
*speechless*
  • #252
DrClaude said:
*speechless*
After two hours of googling, I would recommend reading this persons comment from below the video, before doing the same:
Jayyy Zeee
I have a degree in computer science and electrical engineering, have been working professionally in the field for over 20 years, and I have no clue how that coil stores bits.
also speechless
  • #253
I would assume it 'stores bits' the same way a shift register who's output feeds its input. There are roulette games based on this. A shift register is loaded with a single bit set to one out of however many wide the register is. For the sake of discussion let's say 24 bits wide. There is an oscillator that runs to shift this single bit around and around. The oscillator is set so it's frequency decays off and it simply stops. Where this single bit that is loaded with a one stops may or may not be where the player guessed it would be.
It is the same with this coil except it is mechanical. There is no need for a clock oscillator to keep the 'bits' moving as this is just a natural property of the coil. I will say it is hard to believe they could get that to work, but it is plausible. I wonder how long was needed to store what they needed to store? How many times around?
This may be nitpicking, but can this thing truly be called 100% electronic considering the coil is technically mechanical? At any rate, someone must have had a bad dream to think that thing up. LOL
  • #254
hmmm...
per wiki; "As of February 2016, 97% of all articles in Wikipedia eventually lead to the article Philosophy."
:nb)
  • #255
Jayyy Zeee
Google ' acoustic delay line memory ' .
There is a mercury column version as well
  • #256
  • #257
OmCheeto said:
My brain almost exploded...
OmCheeto said:
Are you trying to kill me?
Only out of scientific curiosity . Did you record the maximum pressure reached ?
  • #258
No.
But it would have been irrelevant, IMHO, if I had.
ps. Let's get back onto the... oh, poop: Old... Things.
  • #259
Gauge or absolute... ?
I ask...
  • #260
There is nothing new about acoustic delay line memories. Don't forget that the integral clock and data pulse timing must be continuously received, restored and retransmitted.
One advantage of delay line memory is that the ALU need only be a one bit serial processor. Another is that CORDIC can be applied to compute the arithmetic +, −, ×, ÷ and √ using shift registers and two serial adders alone. Later, with the addition of diode array lookup tables, all the transcendental functions could be implemented.
https://en.wikipedia.org/wiki/CORDIC
RPN and CORDIC went on to be used in the HP calculator range.
CORDIC was implemented in all the intel 80x87 FPU coprocessors.
  • #261
DrClaude said:
*speechless*
Me too.
What I liked most about the video was at time 7:26 when Cliff said, "Why do I work on this? It's partly out of respect of those who came before me." Reminds me of this quote from a PF member: " ... Restoring some fine machine is honoring somebody's hard work." @Jim Hardy
OmCheeto said:
Your effort is appreciated.
From piano wire to silicon processors. Who would have thought ...? Thanks.
  • #262
Best thread on the entire Internet... I am fascinated by the development of electro magnetic technology through time, and love old electrical and computer equipment. Once, I was puttering around in northern Vermont near the Canadian border, and a couple had a garage sale out. It was her late father's stuff, a former electrical engineer. It was half a dozen shelves crammed with meters, gauges, scopes, TRS-80s, Lisa's, Apple IIs, Commodore 128s, amplifiers, tools, etc.
I had to leave quick, I could feel my wallet squirming to get out of my pocket... Viewing this thread is much safer.
  • #263
Here is a very old relay from a Grinder built around about WWII, using the once popular technique of mercury switching, note the wires are insulated with insulating porcelain beads.
  • #264
An old abandoned lift control room.
  • #265
Nice. Can you say where it's located?
  • #266
darkwood said:
... note the wires are insulated with insulating porcelain beads.
And note the spare lamp. Good stuff.
  • #267
@dlgoff
Yes its in what used to be an old textile mill in West Yorkshire UK which it would have been operating a lift between 2 floors only.
Edit ...
Yes! I forgot to say ignore the spare lamp, there are actually 2 mercury bulbs one behind the other, the beads were used because of the flexing the conductor would go through and the insulation materials of the day wouldn't have held up to the repeated movement.
  • #268
I've had this air pressure regulator of a while and don't know a lot about it. It looks like it dates back to the 1920's. Check out the Bakelite knobs.
from https://lib.bgsu.edu/finding_aids/items/show/149
By 1926 the company name changed to The DeVilbiss Company as their product lines continued to expand to include air compressors.
  • #269
Sometimes a little new can help the old. Like this vacuum angle valve I've added to my vacuum system. I have two Edwards E2M8 rotary pumps and with the valve, I can use the second Edwards to get a quicker pump down so I can turn on the diffusion pump sooner.
Here are the Edwards pumps:
Here are two views of the angle valve:
Adds a little beauty doesn't it?
  • #270
  • · Replies 25 ·
  • · Replies 30 ·
  • · Replies 26 ·
10K
