Solving Bernoulli's Equation Homework w/ Tank of Water
The discussion revolves around solving a homework problem involving Bernoulli's equation related to a tank of water with a hole at the bottom. The key equations mentioned include Bernoulli's equation and Torricelli's law, which is a specific application of Bernoulli's principle. Participants clarify that the height of the water level can be calculated using these equations, with one contributor estimating the height to be 0.09 meters. The relationship between the horizontal velocity of the water and the height of the water in the tank is emphasized as crucial for solving the problem. Overall, the conversation highlights the importance of applying Bernoulli's equation and Torricelli's law to determine pressure changes and fluid dynamics in this scenario.
noagname
You have a tank that is on top of a 1 meter post. The tank is filled with water to an unknown height. At the bottom of the tank there is a 3.5mm hole that is squirting out water a horizontal distance of .6 meters.
Bernoulli's equation p1 +.5*rho*v1^2 + rho*gravity*height
A1v1=A2v2
delta X = 1/2*acceleration *Time^2
I tried a couple different things that didn't work out, so far I have v= (19.6H)^(1/2) and the equation solving for delta X.
What I really want to know, that will help for all of my problems is. Is there an equation where I plug in change of speed, or area and I get the pressure change. Anything of that sort, or is Bernoulli the only why to go?
Thank You
Hmmm, it sounds like bernoulli's equation is what you are looking for. Torricelli's law might be what you are looking for, but then again it is just another form of bernoulli's equation.
And for this problem, you simply have to relate torricelli's law to what happens at the opening.
I height of the water level in the tank i calculated to be 0.09m. Not sure if this is correct though.
Thanks that correct, how did you figure that out.
Like what i said, you have to relate torricelli's law to the horizontal velocity. The rest is simple.
Yea I just figured it out, thanks
