jderulo
- 34
Hi
Can anyone advise how the following equation was derived.
http://uploadpie.com/PYLrD
##\frac{Q}{wD}=## velocity at the left of the figure, where w is the width of the channel. So the area is wD.jderulo said:I took the expression as meaning the velocity - I know it states for Q but it does not multiply by area anywhere.
Chestermiller said:Hey Boneh3ad,
Have you noticed that the given answer is not dimensionally correct. They left out the width of the channel (if the really mean that Q is the volumetric flow rate).
Chet
Me neither, if you are referring to the dip in the upper surface.boneh3ad said:Yes. I was able to reproduce the formula from the problem with the added ##w## term included, but I am not 100% convinced that the assumptions used to get there make a whole lot of sense to me at the moment.
Chestermiller said:Me neither, if you are referring to the dip in the upper surface.
Chet
except the expression describes Q/w instead of just Q .
256bits said:I would think a unit width is implied, which makes the expression easier to work with.
Multiply by the whole width to obtain the total flow in the channel.
Bernoulli's equation is a mathematical equation that represents the conservation of energy in a fluid flow system. It states that the total energy of a fluid remains constant along a streamline, meaning that the sum of its kinetic energy, potential energy, and pressure energy remains the same.
The formula for Bernoulli's equation is derived by applying the principles of conservation of energy to a fluid flow system. This involves using the basic equations for fluid dynamics, such as the continuity equation and Euler's equation, and simplifying them to obtain the final form of Bernoulli's equation.
The main assumptions made in deriving Bernoulli's equation include the fluid being incompressible, non-viscous, and irrotational. It is also assumed that the flow is steady and has a constant density.
No, Bernoulli's equation can only be applied to certain types of fluid flow systems, such as those with steady, incompressible, and non-viscous flows. It also cannot be applied to flows with significant changes in elevation or flows with significant frictional effects.
Bernoulli's equation has many practical applications in various fields, such as aerodynamics, hydraulics, and meteorology. It is used to design airplane wings, calculate water flow in pipes, and predict weather patterns. It is also used in medical devices like ventilators and nebulizers.
