Bessels Equation J(κx) instead of J(x)
  • Thread starter Thread starter gmanmtb
gmanmtb
Hello all, I seem to be stuck trying to prove this one, I'm not sure if I'm headed down the right path or just missing something obvious
The equation x2y''+xy'+(κ2x2-p2)y=0, where κ constant, appears frequently in applications. Prove that J(κx) is a solution by changing the form of Bessel's equation of order p. Do this by letting \widetilde{x}=κx in the above equation and apply the chain rule.
Well the first solution of Bessel's equation is
Jp(x)=\sum^{\infty}_{k=0}\frac{(-1)^{k}}{k!\Gamma(k+p+1)}(\frac{x}{2})^{2k+p}
I believe the method I should be using is to use y(x)=Jp(κx)=Jp(\widetilde{x}) but from there I can derive y'=\sum^{\infty}_{k=1}\frac{(-1)^{k}(2k+p)}{k!\Gamma(k+p+1)}(\frac{\widetilde{x}}{2})^{2k+p-1} and y''=\sum^{\infty}_{k=2}\frac{(-1)^{k}(2k+p)(2k+p-1)}{k!\Gamma(k+p+1)}(\frac{\widetilde{x}}{2})^{2k+p-2} but from there I get fuzzy, I can't replace \widetilde{x}=κx in a way that works out.
No. Make a change of indepedent variable and then solve for y in terms of \overline{x}
For example, if \overline{x}=kx, then:
\frac{dy}{d\overline{x}}=\frac{dy}{dx}\frac{1}{k}
solve for dy/dx, then compute the second derivative in terms of \overline{x}, solve for d^2y/dx^2, then substitute those into the original equation to obtain an equation in y(\overline{x}) for which J(\overline{x}) is a solution, that is, J(kx).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
