What is the most effective tap for threading stainless steel?
In summary: I am going to mount the taps in the drill press rather than doing it by hand.I tried using one of the broken HS taps and rounded it off a bit with my dremel. Afterwards I placed it in a drill press, with my piece placed in the vice. I used lots of lubricant and it worked like a charm without breakage. Drill press is the way to go for sure.
kolleamm
477
44
I need to know what is the strongest most reliable tap for threading 6-32 into stainless steel. I used like 3 cheap steel taps and they all broke. Any advice is greatly appreciated.
Thank you
I used to use spiral flute machine taps on various stainless steels, all about 30 HRc hardness. They worked OK even as hand taps but I would always use a drill press or lathe if possible. Just tighten the chuck with enough force so the tap will work, but then spin in the chuck when it hits the bottom of a blind hole and not break.
Likes kolleamm
Thanks for the advice, I went ahead and ordered some 2 flute spiral taps. Fingers crossed they work.
Many stainless steels work harden and so must be drilled and tapped with HSS tools.
Some require cobalt high speed steel = HSS-Co, or carbide tooling.
It is essential that you use a cutting fluid. http://www.bssa.org.uk/topics.php?article=192
Likes Astronuc, sysprog and kolleamm
Ideally use starting and finishing taps .
For hand use the HSS TiN coated progressive cutting series of taps gives excellent results on difficult materials .
<Link to discontinued product has been deleted.>
Likes kolleamm
Here is what I ended up buying. Will this work?
http://m.ebay.com/itm/Qty-3-New-Greenfield-6-40-NF-GH2-HSS-2-Flute-Spiral-Point-Gun-Plug-Taps-/171887965628?txnId=1538252098007
Also if you know any taps for stainless on eBay (preferably in US) please do put the link I really need to get this right.
Thanks for all your help
I'm on the other side of the planet and I buy unusual taps from Victor Machinery Exchange in Woodside, New York, USA. They have the contacts to get special taps made to order if needed. http://www.victornet.com/departments/TAPS/100.html
If the stainless steel you have does not finish well then you might consider drilling an oversize hole, then using an STI tap and an insert.
That will give you a very good finish on the "recoil" thread insert. It also uses a larger tap that is less likely to break.
Likes sysprog
I will have a look at them for sure.
Also here is what it says on the taps that broke --- 6-32 NC HS GH3 USA 0416M4R
By HS do they mean hardened steel? I'm guessing it's not as good as high speed steel?
Thanks
Cheap taps are commonly made from Carbon Steel. More reliable, harder taps are made from High Speed Steel.
HS is almost certainly “High Speed”, the steel goes without saying.
G H3 is probably the finish and oversize. H3 may mean 1.0 to 1.5 thou oversize.
Find some way to support the tap in line with the hole. Experiment with cutting fluid, oil or soap. That will almost certainly reduce breakage. Some taps in some materials produce the best finish by cutting continuously. Others require a slight advance, then a reverse to break off the cuttings. You will need to experiment to find the best technique.
Corrosion is usually the most important parameter, but if possible select a grade of stainless that is free machining.
Likes sysprog
I will try to mount the tap in the drill press rather than doing it by hand in that case.
One thing that is important when tapping difficult materials is getting the pilot hole the right diameter .
Using pilot holes slightly larger than the theoretical correct size eases the load on the tap considerably and reduces chances of breakage .
Likes sysprog and kolleamm
Use a tap lubricant specifically for stainless steel. Tap Magic is commonly available. And never turn the tap more than 1/2 turn without backing off at least 1/4 turn. Other than that any decent quality tap will work. It's also a good idea to have a starter tap and a plug tap. The starter tap makes it easier to start the threads "square". If you start at an angle you will not be able to complete threading, and the tap will break.
Likes sysprog and gjonesy
I have successfully threaded the holes. I used one of the broken HS taps and rounded it off a bit with my dremel. Afterwards I placed it in a drill press, with my piece placed in the vice. I used lots of lubricant and it worked like a charm without breakage. Drill press is the way to go for sure.
Thanks for the help everyone.
Likes sysprog and Bandit127
Sorry if you know this but... Are you just trying to screw the tap in or are you doing the normal half turn in and a quarter turn out?
I tried it both ways without the drill press and it broke regardless. Funny thing though I just screwed it in in the drill press and it worked even without turning it back.
I used ridgid for most purposes, but "working a tap" not (over working it) usually produces the desired results . Use a LOT of cutting oil and if you get in a bind stop, HSS an CHS taps will snap just as quick if not quicker than any of the cheapo taps you can buy if you over work them in stainless.
These are pretty good:
http://www.northerntool.com/shop/tools/product_200624059_200624059
Likes sysprog
True, also I found a very easy way to get small broken taps out is by hole punching it about 20 times. It just flies right out.
Likes gjonesy
Different stainless steels work harden differently. If you “work” the tap you may harden the material, then break the tap when it hits the previously hardened wall. If you continuously turn the tap the chips will be hardened but the material being cut will be fresh and normal hardness. The speed of cutting is important because the hardening process is a chemical phase change. In some materials, if you back off torque momentarily you may hit a hardening wall.
Avoid machining old, salvaged or unidentified stainless steel. You will probably need carbide tooling.
There are different flute profile taps, spiral flute taps are designed to cut continuously while straight flute are designed to be reversed to break the chips. Don' be mislead by “spiral point”, in hard materials they are often as bad or worse than straight flute because they clog with chips, especially in blind holes. The spiral path of the flute decides the curl of the chip and the quality of the thread finish.
There are many different stainless steels. What grade material are you threading ?
How long or deep is the thread you are cutting? Blind or through hole?
Is your material new or aged? Has the material been subjected to cold temperatures? for what periods?
Likes sysprog
Could you explain the material hardening? I still don't fully understand it. The stainless type is 420
I believe your 420 grade is a “precipitation hardening” steel.
Start here;
https://en.wikipedia.org/wiki/Precipitation_hardening
Then look at this data article and data, where Dura grade 420 is listed as 4021, 4028, 4031 or 4034.
http://www.outokumpu.com/en/products-properties/more-stainless/stainless-steel-types/martensitic-and-precipitation-hardening/Pages/default.aspx
http://www.outokumpu.com/en/products-properties/more-stainless/machining-cutting-and-grinding/Pages/default.aspx
You have chosen a difficult material to work with. Is it sheet, or bar ? Do you need it to be magnetic ?
I expect it to harden on the shelf if stored colder, or for longer. Find the data on thermal storage requirements prior to machining.
Any time you are tapping a hole you are creating friction and friction creates heat, that tends to change the crystalline structure of the metal. That being said I highly doubt that will happen when hand tapping a hole in stainless steel. I used to thread pipe with a ridged pipe machine and that creates a lot of heat and I've never seen it (harden the steel). to harden any kind of steel you basically have to get it cherry red then cool it rapidly. Stainless steel tends to be a bit harder then mild steel anyway. Most of the trouble with taping steel comes from the hole itself, if you don't (size) the hole correctly for instance if the hole an tap are different sizes or if the hole is slightly (wallowed) it can grab the tap and put it in a bind. I have seen aluminum break taps, its so soft it grips the tap and the metal chips get hung up and the tap just breaks. It happens, you just have to work with it.
https://en.wikipedia.org/wiki/Hardened_steel "In order to make steel harder, it must be heated to very high temperatures"http://www.azom.com/article.aspx?ArticleID=1141
"Hardening
Like low alloy steels, martensitic stainless steels are hardened using tempering, quenching and austenitising. Austenitising temperatures range from 980 to 1010°C."
420 stainless is "martensitic stainless"
http://www.spiusa.com/stainlesssteel_overview.php
Likes kolleamm
Yeah the harder tungsten carbide taps will shatter like glass if you shock them. I have actually seen taps break simply from dropping them on concrete floors (probably cracked from use already). Most of the hardened tooling has a fracture point. I got a carbon steel piece hung up on a piranha "punch" and thought I could just hit it with a hammer and knock it off, the piranha punch broke off in the hole.
You are being pessimistic. It is not a black art, it is a science.
There is an optimum way to perform any operation. If you are breaking tools then you do not know what you are doing. If you use a spiral flute tap made of the right material, with the correct cutting lubricant and the correct technique, then it will not break the tap.
Likes sysprog
Baluncore said:
You are being defeatist. It is not a black art, it is a science.
Thanks guys I think this sort of knowledge is very good to know, and you will mess up at some point when first learning it. As long as you learn something from it that's what's important.
On another note, is there any materials out there that you can't tap with anything? I'm thinking Inconel for example.
Thread closed temporarily for Moderation...
Thread re-opened after a cleanup. Let's stay on the technical topic please folks. Thanks.
Brittle materials cannot be tapped but they can be ground. I think any non-brittle metal can be tapped with the correct tool material, profile and process.
Carbide starts as a powder mixture, that can be compressed and moulded like clay, then it is fired as a ceramic in a kiln. It can then be ground with diamond tools to make a carbide tap that might cut a thread in the hardest metals.
There are often better ways of engineering a solution than using a carbide tap. Consider a spotweld, a captive nut or a nutsert.
Internal threads in components which are being CNC machined are commonly thread milled now . Special cutters combined with the motions of the machine generate very accurate threads rapidly .
Thread Milling
Likes sophiecentaur and Baluncore
Thank you
you can try spiral point tap with TicN coating and middle range of relief angle...
  • #31
Baluncore said:
it is essential that you use a cutting fluid.
I have some really thick stuff which has been good to me so far.
It's easy to go too far but I 'control myself' to use very small angles. OTOH, for the right material and the right tap (and the right drilling size) 'they' (manufacturers) seem to just tap in one go with continuous rotation. That can avoid the work hardening situation but you need to keep your nerve and have everything just right.
A good technique and fine if you can get to the other end of the hole but the really awkward situations are often the ones that you can't get there and the hole is blind and you have to do by hand at a funny angle.
I don't have any coarse threads but that must be one way of approaching the problem.
  • #32
Let me share my little experience.
Never tapped #6x32 (M3.5x0.8 in metric system), but have used M3x0.5 in different stainless steels.
Main problem is not wear resistance, but toughness. Easy to break. Solutions:
Basic rule is great lubrication. Everybody knows, but have to remind anyway.
1. Spiral flute.
2. Interrupted thread.
3. Low friction coating.
4. HSS-PM (powder steel) - it has almost double toughness of regular high speed steel.
5. Set of taps.
I have always used HSS-PM taps. Sometimes sets (for titan), sometimes machine type with TICN coating.P.S. Removed links for example of taps, cause - OMG - I am automatically become a spammer 🤦‍♂️
Likes berkeman
1. What is the best tap size for threading stainless steel?
The best tap size for threading stainless steel depends on the specific size and type of stainless steel being threaded. Generally, a smaller tap size is recommended for thinner stainless steel while a larger tap size is needed for thicker stainless steel. It is important to consult a tap and die chart or a machining expert for the best tap size for your specific application.
2. What type of tap is most effective for threading stainless steel?
The most effective type of tap for threading stainless steel is a spiral point tap. This type of tap has a pointed end and flutes that spiral up the tap, which helps to push the chips out of the hole as it cuts. This reduces the risk of chip buildup and breakage, making it ideal for threading stainless steel.
3. Can I use a standard tap for threading stainless steel?
It is not recommended to use a standard tap for threading stainless steel. Stainless steel is a hard and tough material, and a standard tap may not have the necessary cutting edges and design to effectively cut through it. This can result in poor quality threads or damage to the tap.
4. What type of lubricant should I use when tapping stainless steel?
When tapping stainless steel, it is important to use a lubricant specifically designed for stainless steel. This can include cutting oils, tapping fluids, or even a mix of oil and water. The lubricant helps to reduce friction and heat, which can prolong the life of the tap and produce better quality threads.
5. How can I prolong the life of my tap when threading stainless steel?
To prolong the life of your tap when threading stainless steel, it is important to use the correct tap size and type, as well as a suitable lubricant. Additionally, it is important to use the correct cutting speed and feed rate, as well as periodically stop and clear any chips that may have accumulated in the hole. Proper maintenance and sharpening of the tap can also help to extend its life.
  • General Engineering
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Chemistry
