Gearing & Torque: Can My Tricycle Motor Get the Job Done?
The discussion centers on a tricycle motor setup that lacks sufficient torque due to a sprocket size limitation. The user proposes a chain configuration involving a 1-inch to 6-inch to 4-inch sprocket loop, questioning its effectiveness for torque enhancement. Responses indicate that this setup will not achieve the desired torque, as the 6-inch sprocket acts as an idler rather than providing a reduction. To increase torque, a different configuration is suggested, involving a smaller gear connected to a larger gear on an idler shaft. Proper calculations for gear ratios are necessary to determine the final torque output.
drwly
I have put together a tricycle, but it only allows for a 4in sprocket on the axel. I have added a motor to the tricycle and do not get enough torque. The motor came with a 6in sprocket, which will not fit on the axil.
My idea is to set it up so the chain goes from the motor 1in to the 6in to the 4in in one continuous loop. WILL this get me the torque I should be getting?
Welcome to the PF.
Can you use the UPLOAD button at the lower right to post a couple pictures of what you are trying to do? :smile:
here is the bicycle basic drawing.
This configuration will not gain you the torque that you are looking for. The 6" gear in the center appears to be acting as a large idler. To increase the torque you would need to run from the small gear at the right side of your drawing to a larger one on the "idler shaft" this would then create a reduction gear of sorts. Than on the same idler shaft have a parallel smaller gear which is connected to the final shaft on the left side of the drawing.
To do the calculation on this one needs to take each pair independently first and then calculate the final ratio using the two reductions.
Likes billy_joule
Thanks I rather figured that's the way it would be.
Drwly
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
