Improve Bicycle Braking System with Momentum Research - Luke Mace
  • Thread starter Thread starter lmace
    Bicycle Momentum
Luke Mace is researching ways to improve bicycle braking systems, focusing on user reluctance to use the front brake due to fears of flipping over the handlebars. He seeks to calculate the minimum speed required for momentum to counteract the reaction force that could lead to a fall. A suggested formula involves equating potential energy change to initial kinetic energy to determine this speed. Additionally, it is noted that the loss of steering control from a locked front wheel may pose a greater risk than the fear of flipping. Effective braking techniques, such as shifting body weight, can help prevent accidents while using the front brake.
lmace
hello to everyone this is my first post on this website but have used it before and found existing posts and answers very helpfull. i am a engineer at bourneouth university studying BSc Computer aided product design, i am currently working on research into a bicycle braking system to improve the users use of the front brake. Even though the front brake is the most efficant of the brakes users are relutant to use it as they are scared to use it because of the danger of flipping the bicycle.
i would like to be able to work out the mimium speed a user would have to be traveling at to allow the momentum to overcome the reaction force of the users arms and center of mass, to force them over handle bars by angular momentum of the locked wheel.
any help would be very much appriacated.
aplogies for grammer/ spelling i am a designer not english student.
regards luke mace
Ok the question seems relatively straight forward so I'll answer it first. But after that I'd like to suggest why fear of going "over the handlebars" is not necessarily the main concern with front brakes on a bicycle.
First the question. I'd say all you need to do is to find the change in PE to raise the center of mass of the bike and rider to the "flipping point" and equate that to the initial KE to solve this.
Assuming that the center of mass of the bike and rider is at a distance "a" above the front axle and distance "b" to the rear of the front axle then equation I get is :
1/2 m v^2 = mg ( \sqrt{a^2 + b^2} - a )
So
v_{\max} = \sqrt{2g( \sqrt{a^2 + b^2} - a)}
Personally I think that the loss of steering that you get if the front wheel locks up is more of a concern than the flipping issue. As you know the steering on a bicycle is an essential part of how you maintain stability, with the rider continuously making minor corrections to the steering in order to keep his center of mass correctly positioned and therefore the bike upright. I know from painful experience that it only takes a momentary loss of steering (due to front wheel lock) when descending on a loose surface before you can end up in a unrecoverable position and the bike goes down.
Usually the brakes on a road bike aren't strong enough to lock up the front. For fast braking, I simply raise myself up a bit and shove the bicycle forward so the seat is under my lower abdomen, moving the center of mass back to prevent flipping over. Mountain bikes on the other hand, at least the ones with disc brakes can lock up the front tire.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
