C/C++ Find Nearest Record in Binary Search Tree | C++ Implementation
The discussion revolves around implementing a function to find a record with a specified key in a binary search tree (BST) and return the two nearest records if the key is not found. The function should return the address of the node containing the key if found, while also setting two pointers, n1 and n2, to the nearest nodes in alphabetical order when the key is absent. The provided code outlines the recursive approach for searching the tree, with adjustments suggested for setting n1 and n2 before returning from the recursive calls. The key points emphasize the importance of correctly updating n1 and n2 based on the comparisons with the current node's key, ensuring that they point to the nearest nodes as required.
skyhyyzlz
Hi everyone, i have a binary search tree proble, please help me..
* Find record with key x in the tree. If not found, return the two nearest records in the tree (in alphabetical order)
* Return values:
* FOUND: Return the address of the node in the tree which contains key x, set n1 = n2 = NULL;
* NOT FOUND: Return NULL, n1, n2 are set to the nearest node to x in the tree, if exist.
* n1 is set to the address of the BSTNode whose key is just smaller than x in alphabetical order, if exists (Otherwise NULL).
* n2 is set to the address of the BSTNode whose key is just larger than x in alphabetical order, if exists (Otherwise NULL).
* NOTE:
* Always return the address of the existing "BSTNode"s. DO NOT allocate new spaces for returned strings.
How can I implement n1 and n2 in the following code for finding the nearest record when the key x is NOT FOUND?
const BSTNode * BST_findNearest( BSTNode * treeRoot, const string & x, BSTNode* &n1, BSTNode* &n2 )
if(treeRoot==NULL)
return NULL;
else if(x < treeRoot->name)
return BST_findNearest(treeRoot->left,x,n1,n2);
else if(x > treeRoot->name)
return BST_findNearest(treeRoot->right,x,n1,n2);
else
n1 = NULL;
n2 = NULL;
return treeRoot;
Technology news on Phys.org
From your question, I think I'm taking same course with you, in same University.
Just simply set n1 or n2 before returning the next node.
const BSTNode* BST_findNearest( BSTNode* treeRoot, const string &x, BSTNode* &n1, BSTNode* &n2 )
if (treeRoot == NULL) return NULL;
if (x == treeRoot->name) {
n1 = n2 = NULL;
return treeRoot;
else if (x < treeRoot->name) {
n2 = treeRoot;
return BST_findNearest(treeRoot->left, x, n1, n2);
else if (x > treeRoot->name) {
n1 = treeRoot;
return BST_findNearest(treeRoot->right, x, n1, n2);
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
