Binary star system distance between stars
In a binary star system with a 90-day orbital period and two stars each twice the mass of the Sun, the distance between the stars can be calculated using gravitational and centripetal force equations. The gravitational force between the stars is expressed as GM^2/(2r)^2, where M is the mass of one star and r is the distance from each star to the center of mass. The confusion arises from the use of r versus 2r in the calculations; the stars orbit around a common center of mass located halfway between them. Thus, the correct approach involves recognizing that the gravitational interaction depends on the distance between the stars, which is 2r. Understanding these relationships clarifies the correct equations needed for solving the problem.
frostking
A binary star system has a period of 90 days. It consists of two equally massed stars each with a mass of twice that of the sun, that rotate like a dumbbell about the center of mass at the midpoint between them. How far apart are these stars?
F = ma v = 2 pi r/T force of g = GMm/r^2 distance = 2r
I set GMm/r^2 = m v^2/r then solve for r and d is 2 r. My problem is that my solution sheet uses force of g = GM^2/(2r)^2 and then force = to M v^2/r I know this has something to do with the fact that we have two stars and therefore, I guess M times M but I am confused... Could someone please explain why the equations used in the solution sheet are the correct ones and why in turn mine are incorrect? Thanks, Frostking
frostking said:
I set GMm/r^2 ...my solution sheet uses force of g = GM^2/(2r)^2
You used r^2 where the distance between them is 2r, they are orbiting about a common center of mass.
Both stars revolve around their common centre of mass which is halfway between them, at distance r, so the centripetal force is mv2/r, but the other star is 2r distance apart, so the gravitational interaction between the stars is Gm2/(2r)2.
ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
