Binomial Expansion Practice Problems: Multiplying Binomials
  • Thread starter Thread starter Meezus
    Binomial
Meezus
After using this formula I got 1-3x + 6x2 for (1-x)-3 and 1+x - 1/8 ∙ 4x2 for (1+2x)1/2 for the second part of the question I'd assume that you're supposed to multiply the equations? I think this done by timing the whole of second bracket by first number (1) then second number (-3x) and then third number (6x2.from the second bracket.
Meezus said:
1-3x + 6x2
Check again the sign of the second term.
I don't see where I'm going wrong here? (-3)(-4)(x)2(1/2) = 6x2
The second term, not the third one.
No one says "timing". The word is "multiplying". But, yes, that's just the distributive law.
Sorry, I'm not seeing the mistake? -3(x) = -3x correct?
The formula for the binomial expansion uses a plus sign in front of ##x## to define the equation: ##(1+x)^n##. While in the question, the sign of ##x## is minus.
Oh I was just looking at it as +(-3) which is same as just -3 so I can't use this formula?
My mistake, would you mind checking to see if I did the first part correct?
You can use that formula, but the sign of each ##x## appearing in the RHS (the infinite sum) must be adjusted accordingly. I will rewrite the formula using different variable notation for the sake of clarity
(1+u)^{-3} = 1-3u+6u^2-10u^3+\ldots
what if you change ##u\rightarrow -x## as you have in the problem?
ooohh it all becomes negative? I see! So its 1-3x - 6x2?
No, that's not how you go about this.
Ok rather than an arrow sign, I will use an equality sign. Make a change ##u=-x## in that formula. Does it help this time?
It's not the binomial theorem that is the problem, it's your basic algebra, especially handling negative signs. I suggest you do a bit of revision of this.
1-3-x + 6-x2 - 10-x3
I know what you did there is simply replacing ##u## with ##-x## without giving heed to the rules of writing the accepted mathematical expression. What does -3-x in that expression mean?
I'm not sure how it should be expressed. -3-x = -(x+3). Should it be 1 - (3+x)? (IGNORE)
Its (-3)(-x) so it should be 3x because its -3 * -x. sorry
Yes, it should have been ##+3x##.
