Biophysics: Amplitude of the pressure wave.
The discussion revolves around calculating the amplitude of a pressure wave from a dolphin's sound at a distance of 20 meters, given its intensity of 50 dB at 1 meter. The initial calculations for intensity are discussed, with a suggestion to verify the final steps to ensure accuracy. Participants emphasize the importance of understanding how the surface area of a sphere changes with distance, which affects the intensity at different distances. It is noted that the total power remains constant while the power per unit area decreases as distance increases. The conversation encourages exploring logarithmic relationships and the proportionality of intensity to pressure to simplify the problem further.
remakm
Say that the logarithmic intensity of a dolphin's sound is 50dB as measured as 1m away. What would be the ampltude of the pressure wave at 20m from the dolphin?
My Question/Problem: How are you supposed to factor in the 20m away?
Po= SQrt(2*Density*Velocity*Intensity)
Intensity = 10Log(I/(10^-16W/cm^2))
Intensity:
50dB = 10Log(I/10^-16W/cm^2)
5.0dB=Log(I/10^-16W/cm^2)
10^5.0=(I/10^-16W/cm^2)
I=10^16/10^5 = 10^11W/cm^2
This is where I am stuck because I think this is where the 20m factors in, I just don't know how exactly. What I am thinking is before I solve for I, I divide 50dB/20m?? Is that correct?
Once I get the correct value for I, I just plug and chug into the Po equation. If I a completely wrong in my thinking, please guide me in the correct direction. Thank you for you help and time.
Hello remakm,
Welcome to Physics Forums!
remakm said:
Intensity:
Double check that very last line in your calculation. I think you divided when you should have multiplied, or used the wrong sign on one of your exponents, or something like that.
From here there are actually a couple of ways you could proceed. But I'll try to stick with the basics to start.
Once you find I you'll know the power per unit area. What's the surface area of sphere of radius 1 meter? Given that, what's the total power?
After you've figured out the total power, ask yourself what is the surface area of a sphere of radius 20 m? So what's the power per unit area 20 m away? (Hint: remember the total power hasn't changed -- only the surface area of the sphere has changed.)
Solve the problem in the above way first. But later, you might find it useful rework the problem a second time (or third time), keeping in mind some useful things about logarithms and decibels.
\log (x^2) = 2 \log x
And since I \propto P^2, [/tex] (for constant density, velocity, etc.) [Edit: and just for clarity, I'm using P [/tex] to represent pressure.]<br /> <br /> 10 \log \left( \frac{I}{I_o} \right) = 10 \log \left( \frac{P^2}{P_o^2} \right) = 20 \log \left( \frac{P}{P_o} \right)<br /> <br /> For a given total power, there is also a relationship involving <i>I</i> and the distance <i>r</i> away from the source (hint: think back to the radius of a sphere). Can you use a similar trick to the above which involves <i>r</i>? <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":wink:" title="Wink :wink:" data-smilie="2"data-shortname=":wink:" /> If you've bothered to follow through up to this point, you'll thank yourself. Finding this relationship (involving how different distances <i>r</i> give a corresponding change in dB), and then reworking the problem makes the problem almost trivial.
