Does Collector Current Depend on Base-Collector Voltage in Common Base BJTs?
  • Thread starter Thread starter Aditya Mysore
    Junction Transistor
In a common base BJT configuration, the collector current (Ic) is primarily determined by the base-emitter voltage (Vbe) according to the Shockley equation: Ic=Is[exp(Vbe/VT) -1]. While some sources suggest that Ic is influenced by the base current (Ib) through the relation Ic=B*Ib, this does not accurately reflect the cause-and-effect relationship. There is a minor dependency of Ic on the collector-base voltage (Vcb), which is illustrated by the Early effect, indicating a finite slope in the Ic versus Vce characteristics. Overall, the fundamental behavior of a BJT remains consistent across different configurations, emphasizing Vbe as the main control factor for Ic. Understanding these dynamics is crucial for accurate BJT application and design.
Aditya Mysore
Does the collector current in a transistor depend on the base-collector voltage in a common base configuration? If so,how does it depend mathematically?
The principle behaviour of a BJT does not depend on the specific configuration (common emitter, base or collector).
In any case, the famous Shockley equation applies: Ic=Is[exp(Vbe/VT) -1].
Hence, the collector current always is determined and controlled by the base-emitter voltage only.
I am aware that in some textbooks and other publications (in particular: Internet) it is stated that Ic would be controlled by Ib because of the relation Ic=B*Ib.
This relation holds, of course, and it is often used for designing simple transistor stages - however, it does not tell anything about cause and effect.
There are many properties and effects to be observed in BJT applications that can be explained ONLY with the above mentioned equation Ic=f(Vbe).
(I would not be surprised if this reply would cause some disagreements from other forum members; I have corresponding experiences.).
Thanks. Can you also explain physically why it does not depend on the voltage of the other junction?
It depends! (I assume the question is if Ic depends, correct?).
The collector current is mainly determined by the base-emitter voltage - however, there is also a small dependency on the collector-base voltage (backward biased).
This dependency is visualized by the "Early voltage" which is a measure of the BJT`s output conductance (finite slope of the Ic=f(Vce) characteristics).
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
