Block Sliding, might use work energy theorum
2 replies · 2K views
datrumpet45
A block of mass 4.2 kg which has an initial velocity of 3.3 m/s at time t=0, slides on a horizontal surface.
If a constant friction force of 10.2N is exerted on the block by the surface, what is the acceleration?
Work Energy Theorum?
.5 m vo2 - .5 m v22
v = vo + at
I found the kinetic energy of the block, then subtracted the 10.2N of friction. Then I solved for the second velocity. I plugged this into the acceleration equation, but the answer was not correct? Can anyone help me?
You might be over-thinking this one. What is Newton's Second Law?
Using the work energy stuff is going to give you a second order differential equation with 2 boundary conditions to solve (initial and final velocity)
Which is probably a bit harder than is required for this problem..
There is however an equation which relates force to acceleration in a very simple way
