Benzoate
- 418
When a body is suspended from a fixed point by a certain linear spring, the angular frequency of the vertical oscillations is found to be \Omega1. When a different linear spring is used, the oscillations have angular frequency . \Omega2. Find the angular frequency of vertical oscillations when two springs are used together in parallel.
Here is a link to the problem that provides hints to the problem: http://courses.ncsu.edu/py411/lec/001/: Go to the Homework section of the webpage, then go to assignment 5, then go to problem 5.2.
F=k*eff*\Delta x
\sqrt{k*<sub>eff</sub>/m}=\Omega
The hint to the problem says I need to calculate restoring force for each cases.
For the parallel case, would each of the two springs exert a contact force on each other since both bodies would be attached to two different springs?
For the series case, both bodies would be in line with each other; would body would behind or in front of the other body, while sharing an attached spring; therefore I know that there is definitely
\sqrt{k*(<sub>1</sub>)/(m)}=\Omega1 ==>
\Omega1^2=k*<sub>1</sub>/m}
\Omega2^2=k*<sub>2</sub>/m}
F1= (\Omega1^2)*m*\Delta x
F2= (\Omega2^2)*m*(\Delta x)
Not sure what my next step should be after that
