Calculating Hydrogen Bohr Orbit Transition and Series using Wavelength 410.7 nm
The discussion revolves around determining the hydrogen Bohr orbit transition responsible for the emission of light at a wavelength of 410.7 nm. The transition belongs to the Balmer series, which includes visible spectrum emissions, with the initial state identified as m=2. Using the Rydberg formula, the calculations reveal that the final transition state is n=6. This indicates that the electron transitions from the sixth energy level to the second level, confirming the transition's classification within the Balmer series. The calculations and reasoning demonstrate a clear understanding of the relationship between wavelength and energy transitions in hydrogen.
Benzoate
Light of wavelength 410.7 nm is observed in emission from a hydrogen source. a) what transition between hydrogen bohr orbits is responsible for this radiation? b) to what series does this transition belong to?
1/lambda=Z^2 *R(1/n^2-m^2) ,
n being the final transition and m being the initial transition state. R is the Rydberg constant and the Rydberg constant for hydrogen is 1.096776*10^7 m^-1 and Z being the atomic number.
Since the the wavelength is light , I know that its going to be in the visible spectrum of the E-M spectrum and the Balmer series is always part o the visible spectrum. the initial transition energy state in the balmer series is always m=2. Therefore since I know the initial transition state , R , Z and the wavelength , I thought I could find the n, the final transition state. here are my calculations below:
1/lambda)*1/(R)= (1/n^2-1/m^2) =>(1/(4.10e-7 m))*(1/(1.096776e7 m^-1))= (1/(2^2)-1/(m^2)) => .2224=(1/4-1/(m^2))=> -1/m^2 = -(.222-.25) => m^2= 1/.028 = 5.97 m = 6
Looks right. But the final state, n = 2... and you're finding m which is the initial state... so the initial state is m = 6.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
