Boiling point and vapor pressure
The discussion centers on the relationship between boiling point and vapor pressure, specifically how boiling occurs when vapor pressure equals surrounding atmospheric pressure. Participants agree that when vapor pressure reaches this threshold, it allows vapor to form throughout the liquid. The conversation highlights that pressure prevents water from turning into steam, and when the vapor pressure exceeds surrounding pressure, spontaneous vaporization occurs. Key concepts include the role of latent heat in enabling molecules to escape from the liquid phase.
  • Understanding of vapor pressure and boiling point concepts
  • Knowledge of latent heat and its role in phase changes
  • Familiarity with atmospheric pressure and its effects on boiling
  • Basic principles of thermodynamics related to phase transitions
  • Research the Clausius-Clapeyron equation for understanding vapor pressure changes
  • Explore the concept of latent heat in detail, focusing on water
  • Study the effects of altitude on boiling points and vapor pressure
  • Investigate the thermodynamic principles governing phase transitions
Students of chemistry, physicists, and anyone interested in the fundamental principles of thermodynamics and phase changes in liquids.
sashankhrao
I am trying to understand the concept of boiling from a very fundamental perspective. Most textbooks say that: as a liquid is heated, it's vapor pressure increases. When the vapor pressure reaches the surrounding pressure(or atmospheric pressure at that point), then boiling occurs.
I agree with the above point.
My question is: when the vapor pressure reaches the surrounding pressure, what physically happens that allows vapor to form all through the liquid for it to boil.
Thanks
Pressure is what prevents a volume of water from spontaneously flashing into steam - be it air pressure above or water pressure around it. If a volume of water gets hot enough that it "wants" to be steam at a certain pressure and the pressure around it is lower than that, it will spontaneously flash to steam.
Thank you for your reply.
So if the vapor pressure reaches the surrounding atmospheric pressure, how does that lead to the pressure around the volume of water being lower than the pressure with which the steam wants to form?
By "wants", do you mean that the molecules break away from surrounding molecules by absorbing the latent heat?
  • · Replies 28 ·
