Bonding of HCL and HF: Why Higher Boiling Temp for HF?
  • Thread starter Thread starter Soilwork
    Bonding Hcl
Hydrogen fluoride (HF) has a higher boiling point than hydrogen chloride (HCl) despite its lower molecular weight due to the presence of stronger hydrogen bonding in HF. The intramolecular forces in both compounds are polar covalent, but HF's intermolecular forces are significantly stronger due to hydrogen bonding, while HCl primarily relies on weaker van der Waals forces. The higher electronegativity of fluorine compared to chlorine contributes to this difference in bonding strength. Additionally, similar comparisons can be made between water and methane, where water's hydrogen bonding results in a much higher boiling point despite similar molecular weights. Understanding these bonding interactions is crucial for explaining boiling point discrepancies in these compounds.
Soilwork
Explain why hydrogen fluoride (HF) has a higher boiling temperature than hydrogen chloride (HCL) even though HF has a lower molecular weight.
Attempt
OK so from the looks of it I think that the bonding that bonds the H to the Cl and the H to the F is polar covalent. So why would it have the higher boiling point if it has a lower molecular weight?? I mean it must have something to do with bonding because a higher boiling point means that more thermal energy is required to separate the molecules.
Any help would be greatly appreciated.
Thanks
The same rationale can be used to explain the difference in boiling point between water (MW = 18) and methane (MW = 16). Why the big difference in these two compounds of almost identical molecular weight?
I think you were on to it when you wrote, "I mean it must have something to do with bonding...".
Well I've been doing some reading and I think I might have it, but I'm not entirely sure. From the looks of it there are the intramolecular bonding forces and the intermolecular bonding forces. So the intramolecular forces are polar covalent because they are responsible for the bonding of the H to the Cl and the H to the F. However, the bonding forces between the various HCl molecules (intermolecular) are weak van der Waals forces. Then for HF we have hydrogen bonding which is stronger. Is this on the right track?
Doesn't F have a way higher electronegativity than Cl, implying that the van der Waals forces of attraction would be significantly greater?
Absolutely on the right track.
ahh cool. :)
Thanks!
This statement isn't quite right. There is significant hydrogen bonding in HCl.
