Book about optimization problems
  • Context: Calculus
  • Thread starter Thread starter TeeTex
    Book Optimization
The discussion revolves around recommendations for books or resources on optimization problems, particularly in the context of preparing for calculus finals. Participants explore the nature of optimization problems, including constraints and maximizing certain variables.
  • Homework-related, Exploratory, Technical explanation
  • One participant seeks recommendations for books on optimization problems to aid in understanding and solving them for calculus finals.
  • Another participant asks for clarification on the specific type of optimization problems, such as whether they involve finding minimum or maximum values and the number of variables involved.
  • A participant presents a specific optimization scenario involving a decorative tree made from wire and paper, detailing constraints on weight and the goal of maximizing the luminous surface area.
  • Another participant identifies the weight limit as a constraint and suggests creating an expression for weight and surface area to apply calculus techniques for maximization.
  • A later reply suggests that the participant's calculus textbook should cover the necessary techniques and provides a link to an online resource for further learning.
Participants generally agree on the need for resources to understand optimization problems, but there is no consensus on specific book recommendations or approaches to the problem presented.
The discussion includes various assumptions about the nature of optimization problems and constraints, which may not be fully articulated or resolved. The specific mathematical steps and expressions for the optimization scenario remain undefined.
TeeTex
hi guys, i am preparing my self for the calculus 1 2 3 final and i need recommendation about optimization problems theories book or something to help me understand how to solve and understand optimization problems and to solve them. Thanks♥
Can you be more specific? Are you referring to like minimum or maximum problems? How many variables? What book(s) are you using for Calculus?
Yes like for example
Each tree is made by iron wire structure a translucent paper cone open at the bottom. The metallic structure of the decoration is obtained
welding on the basic circumference two linear pieces corresponding to two apotems of the cone.
The weight of the paper used is p1 = 25g = m2, and each conical cover is obtained from a sheet
35 cm square on the side. The weight of the wire is instead equal to p2 = 0; 08g = cm, while
the electric apparatus (lamp holder, bulb and cable) and the bill hook weigh 30 g per
each decoration.
Each suspension point of the support can bear a maximum weight of 40 g.
The single tree is tantopièu decorative, how much greater is the luminous surface (therefore the
base does not count).
Determine the optimal measures of decoration
[Translated from other language]
So you have a limitof 40 grams. This is a constraint. You have some items (paper wire and fixture) add up to make total weight. You need to create an expression which represents the weight in some variables. It looks like you want to maximize the light surface area? Create an expression for surface area. Use Calculus to find a maximum. See if that fits into the constraints. The amount of paper is also constrained.
So any recommendation about any kind of book that teach that stuff ? :) or resource/s
Please i would really appreciate it! :-p
  • · Replies 17 ·
11K
  • · Replies 26 ·
