Box Problem Kinetic/Static Friction
  • Thread starter Thread starter ilovejesus
    Box Friction
The discussion revolves around a physics problem involving two stacked boxes, with the top box weighing 20 N and the bottom box 50 N, while neglecting friction with the floor. The maximum force F that can be applied to the top box for both boxes to accelerate together was initially calculated incorrectly as 100 N, but clarification was needed regarding whether the weights were given in Newtons or kilograms. When pulling with a force twice the maximum value, the calculations for acceleration were also incorrect, with the need to reevaluate the mass of the top box. The direction of the frictional force was emphasized, particularly how it opposes relative sliding between the two boxes, which is crucial for accurate calculations. Understanding the interplay of forces and friction is essential for solving the problem correctly.
ilovejesus
Here's the question: Two boxes are placed on top of one another. The top box has a weight of 20 N and the bottom box has a weight of 50 N. You can neglect friction between the bottom box and the floor, but uS = 0.5 and uK = 0.4. You can assume g = 10m/s^2. Both boxes are initially at rest.
a) you tie a string to the top box and exert a force F to the right so both boxes accelerate together to the right with the same acceleration. What is the maximum value of F for which the boxes have the same acceleration?
I did F = uS(m1 * g)
F = 0.5 (20N * 10m/s^2) = 100N
Is this right??
b) what if you pull witha force twice as large as the maximum value you calculated? Determine the acceleration of the box now. You should get two different values.
I did: 20 N = m1*a - uK(m1*g) and got 24 m/s^2
and m2*a = -uK(m1*g) and got -1.6 m/s^2
Is this right??
Not quite. At least not the way the problem statement is written as it is now.
Hint: Does the problem statement give the weight in Newtons or the mass in Kilograms?
Okay, here you're back to 20 N (instead of 200 N) for the twice the force of the first part. But re-evaluate the mass of m1. Is it 20 N or 20 kg?
You might want to redo the above too, as long as your at it. But there's one more hint I'd like to give first. This part is special, and I think you might be missing an important idea.
Before, when you worked out the part for m1, you correctly made sure the direction of the frictional force was such to oppose the direction of the relative sliding. In other words, in this particular case of m1, the frictional force is in the opposite direction as the string's pulling force. [You are correct on the frictional force's direction for that part :approve:]
But in the case of m2, what is the direction frictional force (on m2) such that it opposes the relative sliding? (By relative sliding, think of the direction of m2 relative to m1. What is the direction of the frictional force as seen by m2?)
There is yet another way to look at the same thing. As the top block m1 slides across the bottom block m2, m2 exerts a horizontal frictional force on m1 (which opposes the direction of the string's force). What does Newton's third law of motion have to say about this horizontal force (on m2)?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
