Bragg Angles + Thermal Expansion
The discussion revolves around calculating the change in Bragg angle (theta) when a crystal's lattice parameter increases by 0.17% due to thermal expansion from 0 to 100 degrees Celsius. The equation 2dsin(theta) = nλ is referenced, but participants express confusion about how to apply it without knowing the wavelength or the new d-spacing. There is uncertainty regarding whether to use the relationship d_1*sin(theta_1) = d_2*sin(theta_2) for the calculation. The lack of information on density and the new angle complicates the solution process. Ultimately, the participants are seeking clarity on how to approach the problem with the given data.
exzacklyright
A crystal is heated from 0 to 100 degrees celcius, its lattice parameter 'a' increases by 0.17% due to thermal expansion. if we observe an x-ray reflection at a bragg angle theta= 19.3 degrees at 0 degrees celcius, by how much will theta change when the sample is heated to 100 degrees C. (don't need to know wavelength or d to solve)
2dsin(theta) = n\lambda
Tried using 1 for d. and just seeing how much it'd change but it didn't come out right.
Should it be d_1*sin(theta_1) = d_2*sin(theta_2) ?
well all we're given is density 1 and theta 1. we don't even know density2 or theta2
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
