Break down CaCO3 into its constituents
  • Thread starter Thread starter rww63
    Break
To calculate the daily throughput of a reverse osmosis plant supplying 4.5 million liters of drinking water with a minimum hardness of 60 mg l-1 as Ca, it is essential to break down CaCO3 into its constituents. The feed hardness is given as 660 mg l-1 CaCO3, while the permeate hardness is only 4 mg l-1. The problem indicates that 30% of the feed will be rejected, which must be factored into the throughput calculation. The user seeks guidance on how to approach this problem, indicating a need for foundational understanding in the sciences. This discussion highlights the importance of clarity in tackling complex scientific calculations.
rww63
in order for a well to supply 4.5 million litres of drinking water per day, at a minimum total hardness of 60mg l-1 as Ca, calculate the daily throughput of the reverse osmosis plant assuming that 30% of the feed to the plant comes out as reject.
a table provides the following info:
total hardness (as mgl-1 CaCO3) at feed is 660 but at permeate it is 4
i suspect i must break down CaCO3 into its constituents however i can't remember how to do this. Iwould be very grateful for a pointer in the right direction.
guys I am only a newbie to both the sciences and this great website, I am not looking for an exact answer but just a clue of how to tackle this question. if any further questions is needed please reply, i really am going off my head trying to get over this mental block I am having.
Perhaps you should post this under the "Other Sciences" sub-forum, also under Homework & Coursework Questions
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
