Understanding BLDC Motor Control: Position, Speed, and Current
The discussion revolves around developing a BLDC motor controller for a Maxon E40 motor, focusing on controlling position, speed, and current using a PID controller. Participants confirm that the output of the speed controller should indeed feed into the current PID controller, and they discuss the relationship between torque, current, and load, clarifying that torque is proportional to current even under load conditions. The importance of current control is highlighted, especially for maintaining speed and torque, with suggestions to use gears for low-speed applications to avoid torque loss. Additionally, there is a mention of the differences between typical BLDC motors and those used in printers, particularly regarding sensor types and wiring configurations. The conversation emphasizes the need for more information and collaboration to effectively control the specific BLDC motor in question.
bagavac
Hi guys,
I'm developing a BLDC motor controller with load. I've bought a Maxon E40 motor . But some things i can't figure out:
I want to control position, speed and current (torque). I use PID controller to do it. In the closed loop system the output of the speed controller should be input of current PID controller.
questions:
1) is this above true?
2) is it true that the torque and current are propotional also with the load?
example: If the torque constant is 2Nm/A and my load is 1Nm i need 0,5A to move the load? or is the torque constant only propotional on no loaded motor...?
btw: why is it needful to controll the current?
BLDC motor in printer
I am studying about BLDC motor.
My teacher gave me a BLDC motor which is in printer machine.
however I don't how to control.
It has 11 unknown outputs.(its seems to be use HALL IC 4 pins)
I have some pic about my motor but i don't how to post.
If there is anyone knowing about it.give ur opinion.
Thanks you very much.
bldc motors are a bit complicated. there's some tutorial around the web explaining how BLDC's work. Last i work on it few months back, the current supplied controls the speed of the motor. current is controlled by chopping the driver or somewhat essentially shutting it on/off. i was using A3936.
a BLDC motor typically has 8 connector. 3 for each motor phase, 3 for hall sensor (1 sensor for each phase), 1 power supply Vcc for sensor, 1 gnd for sensor.
yes the output of the hall sensor goes back to the input. you get the timing from the motor poles through the hall sensor. from this timing, # of motor poles etc you can find the rpm of your motor. based on this result, you compare with what speed you want (ie: your speed corresponds to some timing). Increase/decrease your current to get that speed.
I got mine to work but I'm not sure if it works right. Mainly because torque is also a factor of current and speed. if you go too slow, you lose torque. So if you want to use brushless and run slow, you have to use a gear to down convert the speed.
hope this helps
He.Thanks your opinion.
I controlled a typical BLDC motor as you say.
but the BLDC motor in printer is differ form a typical motor.
while a typical motor uses HALL sensors ,my BLDC motor uses HALL IC.
He.I can send you some info abt my BLDC motor?
Give me your email to contact!
Ok!thanks for ur help!
what is the chip? Can you look at the data sheet for the chip. More information is required. What are your 11 pins,
hi.i don't know how to decribe.
it will be more convient if we can contact each other by email.
are you ok?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
