Build a $100 Robotic Arm with CCD Motion Capture
  • Thread starter Thread starter tusavision
    Arm
The discussion focuses on building a low-cost robotic arm using CCD motion capture for position control instead of traditional methods like optical encoders. The user is exploring the feasibility of using cheap geared DC motors and DIY worm wheels to manage torque issues. Suggestions include considering the potential lag in the motion capture system, as well as the complexity and accuracy challenges it may introduce. There is also a recommendation to start with simpler RC servos for easier control before advancing to more complex systems. Overall, the conversation emphasizes balancing budget constraints with the technical requirements of the project.
tusavision
http://builders.reprap.org/2009/09/bambot-bamboo-robot.html
I want to see this design move forward. Before I can work on the mechanical engineering aspects of the motors: I want to work on my position control system.
(Cheap geared DC motors like those from solarbotics/chinese drill motors seem ideal if I can convert them into servos somehow.
I'm also considering DIY worm wheels drawing from the astronomy or http://en.wikipedia.org/wiki/Magnetorheological_fluid between clutch plates to manage the holding torque issue with DC, but that's getting ahead of myself.)
Rather than going with the potentiometer/optical encoder positioning that seems popular on many systems/servos: for ultra-low budget reasons: I'm inclided to go with a CCD active motion capture setup wiimote style.
http://www.chinavasion.com/product_info.php/pName/micro-wired-pinhole-color-audio-camera/
Now: If I put and IR filter on several of these cameras and affix them to the arm on each axis of movement: I imagine I can keep the robotic arm in a room with line of sight to multiple reference IR LEDs, and I can use this code:
http://code.google.com/p/lasertraq/
to translate the video feed into positional feedback on the arm.
I guess is what I'm looking for is suggestions/constructive criticism. Trouble you anticipate I might run into from your experience in such things. Not being a CS/Mechatronics expert, I have no experience to draw from on the: "in over my head" scale.
Flame away.
Talked to several people about this. One thought I should use this motion capture technique to supplement traditional positioning feedback from an optical encoder. The other didn't have an opinion one way or the other but didn't see anything immediately wrong with the idea. Some discussion about the possibility of lag.
The "geckodrive" would be one option for controlling it, although: these solarbotics motors are so low voltage: that may be overkill.
It didn't stike me at first, but the idea of using bamboo as a material really tickels me. Competitive with acrylic, however universally available, and less brittle.
Can anyone offer a prediction on lag/anticipate any problems with this approach before I start sinking money into it?
Perhaps this is the wrong subforum? Can a moderator move me to Electical engineering or computer science? Something more relavent? I think the real issue at this point is an estimation of the lag that such a control system would have to deal with.
I think the ABB flexpicker robot uses image sensors for positioning - but with a traditional jointed arm it's going to be easier to just use encoders or encoders+inclinometers on the arm segments
I think you will need to consider what is available and easy enough for you to do. If you have serious equipment at your disposal and sufficient time, it would certainly be nice to work out a more advanced system. However having said that, you may want to consider starting at the low/easy end and then working your way up. From my experience with robotics/motion control (designed & built 4 different CNC routers/mills & 2 robotic arms), you may want to start off with simple RC servos. They are easy to control and take care of themselves. A step up from that would be a system with stepper motors & perhaps encoders (if you don't want to run this in open loop). The optical system sounds like overkill. The issue most likely with that would be accuracy/resolution but also complexity.
But good luck anyway.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
