Building a Successful Faraday Cage for Cell Phone Signal Cancellation
A physics project aimed at building a Faraday cage to cancel cell phone signals faced challenges, achieving only partial signal reduction with initial designs using chicken wire and wire mesh. The most effective designs included a grounded solid metal box and a cage lined with steel wool, which significantly improved results. Grounding the cage was debated, with some suggesting it enhances performance due to the dielectric properties of the metal. Questions arose regarding the relationship between the cage's gap size and the wavelength of cell phone frequencies, highlighting the importance of design in signal cancellation. Overall, the discussion emphasized experimentation and adjustments to achieve a fully effective Faraday cage.
Krankles
For my physics project I decided to make a Faraday cage to cancel out cell phone signal.
For my first attempts at making a successful project I used chicken wire and wire mesh to make a cylindrical cage. Our goal was to cancel out all cell phone signals within the cage but we only managed to drop a few bars in service. We tried grounding the cage but we didn't notice any difference in signal strength. One cage had about 1cm gaps in between wire and the other had about 1mm. The second cage did produce better results but nothing satisfactory. IF anyone has any experience or has an idea for building a Faraday cage it would be appreciated.
The most effective Faraday cage would be a solid metal box (grounded). One other thing that might work well is steel wool.
Keep us updated on your results.
Yea I knew the solid metal box would work well but never thought of using steel wool. I will try that and keep you guys posted on the results.
Thanks lzkelley, you're a legitimate badass. The steel wool idea worked. We made two working Faraday cages. One is a box lined with steel wool and the other is the solid metal box that is grounded.
Does grounding the box actually make a difference? I wouldn't have thought it would matter.
If you think of the metal as perfect conductors then no it doesn't matter -> either will work.
But if you take into account the dielectric properties of the metal, the grounding reduces it by an order of mag or 2, depending on the situation.
Hi Krankles welcom,
Did you tried put a radio inside of your first cage(chicken wire)? Does it working there?
I want to ask that, what is the relation between the wavelength and the gap of cage? As i know cellphone freq. is 900-1800MHz and velocity is 3*10^8 m/s thus, wavelength is max 1/3 meter. How this wave come inside?
