Building an rc chopper and have a question to do with damping vibrarions
line2
I have already built most of the chopper but am trying to add an accelerometer. Let's say the blade is rotating at 600rpm, this is causing vibrations throughout the vehicle at 10hz. I want to make a compartment which doesn't feel most of these vibrations. I'm thinking of building something using springs. Here's the idea drawn out in paint http://imgur.com/koLyO.png
The problem is, i don't know enough math to calculate the optimal k value for these springs. I have taken a couple years of physics and calc but it doesn't really help me.
How do I find the optimal k value for the springs assuming the mass is m and 1cm by 1cm by 1cm. The container will be 3cm by 3cm by 3cm.
note: All the springs are the same and have the same length and k value. In the above example, they would all be of length sqrt(1^2+1^2+1^2)=sqrt(3)
thanks
Have you modeled the problem to any specified equations that you like us to look into?
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
