Building Faraday Flashlight Help
  • Thread starter Thread starter psionicarrow
    Building Faraday
The discussion centers on building a Faraday flashlight, highlighting two main issues. The user is unable to charge a 16V 2200uF capacitor connected to a 12V DC motor, as the LED only lights up while the motor is actively turning. There is speculation that the capacitor's size may be causing the problem. Additionally, the user seeks guidance on calculating voltage production from moving a magnet through coils connected to a wave bridge rectifier. The conversation emphasizes troubleshooting circuit design and component selection for effective functionality.
psionicarrow
I need to build a faraday flashlight and I have two problems.
(1) When I use a 12V DC motor connected in parallel to a capacitor (16V 2200uf) and then to an LED assembly, I can't get the capacitor to charge. (2) If I wanted to use a magnet and coils connected to a wave bridge rectifier and then to a capacitor and LED, how would I calculate the amount of Voltage produces by moving the magnet?
I've already built a flashlight with the DC motor, it is able to turn on the LED but the capacitor just does not charge. I've put in a switch between the capacitor and LED and all I can get it to do is light up when I'm turning the motor and the switch is on; when the switch is off I turn the motor but when I flip the switch on the LED doesn't light up. Could the problem be that my capacitor is too large?
Can you post a schematic of your circuit?
I think you can see this http://www.lightflashlights.com/ . It's very well. And I think that it's very useful.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
