How Do Bullet Impact and Spring Constants Determine Oscillation Characteristics?
  • Thread starter Thread starter Biggidy
    Bullet Spring
The discussion revolves around calculating the oscillation characteristics of a block-spring system after a bullet collides with the block. The user initially calculates the period as approximately 1.2 seconds and estimates the amplitude as 45 cm. However, feedback indicates a misunderstanding of the collision type, suggesting that momentum conservation should be applied instead of assuming an elastic collision. This correction is crucial for accurately determining the post-collision velocity and subsequent oscillation parameters. The conversation highlights the importance of using the correct physics principles in solving such problems.
Biggidy
1. Homework Statement
A 4kg block resting on frictionless surface is attached to spring of k=100n/m. A 2g bullet is fired at 100m/s at the block. What is the period and amplitude of oscillations?
2. Homework Equations
1/2mv2 = kinetic energy
1/2kx2 = elastic energy
2 x pi x square root (mass/k) = period
3. The Attempt at a Solution
No answer choices given, just seeing if my thought process is valid.
First, period. 2 x pi x square root (4/100) = 2 x pi x 2/10 = 4pi/10 = approx. 1.2
Next, amplitude. 1/2 (.002g) (100m/s2) = 1/2 100n/m x2
therefore, x equals out to .45, or 45 cm?
Does this make sense, I think I have the period right, but one of my friends got 1 cm for the amplitude and another one of my friends got 0.83 seconds for the period. Any ideas?
Thanks
There's been a mistake.
You took an inelastic collision for a completely elastic one.Instead conserve momentum to find velocity of bullet-block system and then proceed for momentum.
That makes great sense. Thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
