Bullet hitting a wood block in a vise. Find initial velocity?
A 7.00 g bullet penetrates a 1.10 kg wood block to a depth of 6.40 cm when the block is held in a vise. The challenge is to determine the penetration depth when the same bullet is fired into the block on a frictionless surface. Key concepts include conservation of momentum, the relationship between kinetic energy and momentum, and the work-energy principle. The discussion highlights the confusion around initial velocity and acceleration, emphasizing the need for simultaneous equations to solve the problem. The scenario contrasts inelastic collisions with the effects of a frictionless environment on penetration depth.
hevans1
A 7.00 g bullet, when fired from a gun into a 1.10 kg block of wood held in a vise, penetrates the block to a depth of 6.40 cm. This block of wood is next placed on a frictionless horizontal surface, and a second 7.00 g bullet is fired from the gun into the block. To what depth will the bullet penetrate the block in this case?
vf^2 = vi^2 + 2ad
p = mv
m1v1i + m2v2i = (m1+m2)vf
Δp = ƩF dt
Honestly, I'm pretty baffled. I can't do anything with momentum without an initial velocity, and I can't find that without acceleration or time. I've seen some other posts that talk about resistive force, but we haven't discussed that so I don't think that's necessary. I think the vise is what's throwing me for a loop. It's inelastic, so there no conserved energy. I'm just not sure what the first step is.
It's a comparison between the vise and the free block.
This is one of those situations where you have to write down a bunch of simultanious equations.
You know that momentum is conserved.
You know the relationship between kinetic energy and momentum.
You know the relationship between work and change in energy, also work and force.
You also know a bunch of kinematic equations and Newtons laws.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
