Calculating the Vertical Displacement of a Block After a Bullet Collision
  • Thread starter Thread starter mathcrzy
    Bullet Physics
A bullet with a mass of 21.0 g and a speed of 190 m/s is fired into a 1.80 kg block of wood at rest, causing the block to rise after the collision. The initial momentum of the bullet must be conserved to determine the block's final velocity after the bullet becomes embedded. Using the conservation of momentum equation, the final velocity of the block is calculated to be approximately 2.2 m/s. To find the vertical displacement of the block, kinematic equations can be applied with the final velocity and acceleration due to gravity. This approach leads to the correct calculation of how high the block will rise after the bullet impacts it.
mathcrzy
A gun is fired vertically into a 1.80 kg block of wood at rest directly above it. If the bullet has a mass of 21.0 g and a speed of 190 m/s, how high will the block rise into the air after the bullet becomes embedded in it?
_____m
Vf^2-Vi^2=2ax
Vf=0
Vi=190
a=9.8
x=?
0^2-190^2=2*9.8*x
x=1841.83m
The answer you have found is how high the bullet will rise in the air if it was NOT embedded in the block, i.e. if the block was never in the way. Here is a hint to get you on the right track:
Remember we are talking about how high the BLOCK moves after it is hit by the bullet. Does conservation of momentum tell you anything about the block's motion?
Conservation of momentum is going to be the same before and after the collision. so the momentum of the block upwards is going to be the same as the bullet before it hits the block.? would i then use the equation (before collision)M1V1+M2V2=M1V1+M2V2(after collision)
Exactly:smile:
Now, what would that equation tell you? Do you know where to go from there?
M1 would be the bullet .021kg
V1 is the bullets velocity 190m/s (initial) 0m/s (final)
M2 is the block 1.8kg
V2 is the block's velocity 0m/s (initial) ?m/s (final)
Then find the V2 final
.021*190+1.8*0=.021*0+1.8*?
3.99=1.8?
2.2=V2 final
Now how do i find delta x for the block?
Ok, now that you have the velocity of the block after the collision, this becomes a kinematics problem. Can you find a way to solve it with kinematics? HINT: You had this part down in you original post...
