Bungee Jumping: Solving for Mass, Cord Length, and Period of Oscillations
The discussion revolves around calculating the period of oscillations for a bungee jumper using Hooke's Law, with a focus on a 58.0 kg jumper and a 20.0 m bungee cord. The calculated period of oscillation is approximately 13.6 seconds. Concerns arise regarding the suitability of the same cord for an 88.0 kg jumper, as the increased mass would cause the cord to stretch more, potentially leading to a dangerous situation. The correct interpretation of the stretch distance is emphasized, clarifying that the initial cord length is 20 meters, not 46 meters. The conclusion is that the heavier jumper should not use the same cord due to the risk of hitting the water.
sona1177
A bungee jumper leaps from a bridge and undergoes a series of oscillations. Assume g=9.78 m/s^2. If a 58.0 kg bungee jumpers jumps from length of 20.0 m and she jumps from a heigh of 66.0 m above the river, coming to rest a few centimeters above the water surface on the first downward descent. What is the period of the oscillations? Assume the bungee cord follows Hooke's Law. The next jumper in line has a mass of 88.0 kg. Should he jump using the same cord?
A) kx - mg= 0
k=mg/x
k= (58.0 * 9.78)/46
k=12.33
w= sq rt (k/m)=sq rt (12.33/58.0)=.4611
w=2pif
w=2pi/T
T = (2pi)/w
T=(2pi)/.4616
T=13.6 seconds
B) kx -mg =0
kx=mg
x=mg/k
(88.0 * 9.78)/12.36=69.6
No, he should not jump using the same cord b/c the cord will stretch and he will not be able to avoid the water.
These answers are wrong and I don't see why.
x is not 46 metres. It is 20 metres because the x stands for how much it stretched. If that doesn't work, try 1/2kx^2.
46 metre is the normal length of the rope.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
