How Far Will a 76 kg Person Fall with a Doubling Bungee Cord?
  • Thread starter Thread starter NicholasAllen
    Bungee Mathematics
To determine how far a 76 kg person would fall with a bungee cord that stretches to twice its natural length, one must consider the cord's behavior as a spring. The force exerted by the cord can be described using the formula F = kΔx, where k is the spring constant and Δx is the change in length. Without knowing the natural length of the cord, calculating Δx becomes impossible, making it challenging to derive a specific formula. A free body diagram can help visualize the forces acting on the person, leading to an equation where the net force equals zero at rest. Understanding the spring constant in relation to the mass and cord length is essential for further calculations.
NicholasAllen
Hi,
I was wondering whether there is a formula in terms of length and mass which would provide how far a person would fall is they were attached to a bungee cord rope which stretched to twice it's natural length when an object of 76 kilos was hung from it at REST from the free end?
I'm finding this difficult as we are not given a natural length... Oh also in this case I am neglecting the height of the person.
I am a Maths C student, so any physics explanations would not be much help as I'm hopeless at physics (whereas quite okay at maths c).
Thanks
You're correct about not knowing the unstretched length. One could think of a bungee cord simply as a spring. In that case, the force exerted is:
<br /> F = k\Delta x<br />
Without the original length, you cannot find \Delta x and therefore the instantaneous force exerted on the mass by the cord.
So does that mean there is no formula?
Because my maths C teacher is convinced there is, and i need it as a preliminary sort of thing to begin an assignment - maybe it is a formula in terms of x, l and m ?
I mean that's the formula for the resistance felt by the person. You could draw a free body diagram; the net force being mass times acceleration. The forces in each direction are mass and the resistance force from the bungee. However, saying that the cord will stretch twice it's length, but not specifying that length will not allow a person to get the change in length of the cord.
This can be done by assuming the rope behaves as a spring as minger described.
-Draw free body diagram of the person at rest hanging from the end of the rope using the known condition (76 kg mass, delta x = l)
-> At rest means no acceleration, therefore the vector sum of all forces adds up to zero. This leads to an equation.
-> Solve for spring constant k in terms of l and m
Since this is homework I'm not going to give you the rest of the solution, but hopefully now that you know the spring constant, and what minger described, you can come up with something on your own for the variable mass case...
If you don't know the natural length, you must know the elasticity constant.
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
