Solve Balloon Height: Buoyancy & Weight Problem
  • Thread starter Thread starter bolivartech
    Buoyancy Height
The discussion revolves around calculating the height (h) a helium-filled balloon lifts when released, considering buoyancy and weight. The buoyant force (B) is calculated to be 3.39 N, while the gravitational force (F_g) acting on the balloon and string totals 3.41 N. The equilibrium condition is established where buoyancy equals the weight of the balloon and the lifted portion of the string. The participant is exploring the relationship between the forces to determine how much of the string's weight contributes to the height lifted. The conversation emphasizes the importance of understanding the balance between buoyant force and gravitational force in solving the problem.
bolivartech
A helium filled balloon is tied to a 2.00-m-long, 0.050 0-kg uniform string. The balloon is spherical with a radius of 0.400 m. When released, it lifts a length h of string and then remains in equilibrium as shown in figure P14.51. Determine the value of h. The envelope of the balloon has a mass of 0.250 kg.
Code:
ρ=  m⁄v
v=  4/3 pi r^3
B=ρ[SUB]air[/SUB] * g * V[SUB]obj[/SUB]
Code:
	B=(1.29 kg⁄m^3 )(9.8 m⁄s^2 )(.26808 m^3)
	B=3.39 N
	m_he=.047986
	F_g=Mg
	F_g=(.347986 kg)(9.8 m⁄s^2 )
	F_g=3.41 N
This is something the prof. said to start with, I'm not sure how this helps aside from proving it has pretty much reached equillibrium. I really just don't know what formula that involves height will work.
Think height in terms of weight of string not altitude
Ok so here is the thought process I am having. Find the change in force, use F=ma to find how much mass is lifted (string). Use that to determine how much in h is lifted.
Code:
mass total / height total = mass lifted / height lifted)
So do I use the small difference in force between my normal force and the buoyent force? .02N I know it doesn't move a significant amount.
I haven't received a response but from what I can tell that is right. I did get the same answer as the prof, now I just have to find out if it was luck or if the process was correct. Thanks for the help!
At equilibrium bouyancy = weight = mass of length of string h + mass of envelope.
ps. remember the people here are in different time zones
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
