Calculating Buoyancy Rate of Rise for a Ship
To calculate the buoyancy rate of rise for a ship, one must consider the buoyant force acting on the object and the resistive drag force from the water. The buoyant force is determined by the volume of water displaced, while the drag force increases with the speed of the ship as it rises. An equilibrium is reached when the buoyant force equals the drag force, allowing for a steady ascent. Although the initial acceleration might be complex due to changing pressure, the transient phase is minor compared to the steady-state motion. Ultimately, finding the speed at which the drag force equals the buoyant force can simplify the calculation of ascent time.
gloo
Can someone give me a formula or give an approximate approach to calculating the time it would take for an object to be raised up (due to buoyancy) from a certain depth of water?
For instance, take a ship (say it weighs 300,000kg and it's a rectangular shape with surface area of 100m square (10m by 10m). If i attach enough air ballons around the ship , what would be the variables and formula to use to get an approximate time it would take to raise the ship to the surface from say 100meters of water (sea water).
I assume that the the surface area of the ballons might be a factor too but let's just leave those out (say i put the underneath the ship). I am not concerned about the acceleration at the end destroying the ship near the surface. I am fearful of this solution turning into a series of calculus equations b/c of the rate of change of pressure as the ship goes higher.
I'm afraid this will be the case. It will be the same as an object falling through the atmosphere and reaching terminal velocity. The object will have a constant buoyant force acting upward, tending to increase its speed, however increase in speed will increase the resistance of the water. It will reach an equilibrium where the resistive drag force will equal the buoyant force. The transient portion may be small compared to the steady state portion, so you could probably get away with finding which speed through the water will give a drag force equal to the buoyant force.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
