Buzzing/Whining sound from speakers when connected to laptop
  • Thread starter Thread starter MrNathan
    Laptop Sound
The discussion revolves around a buzzing or whining sound that occurs when speakers are connected to a laptop. Participants explore potential causes and solutions, considering both hardware and software factors.
  • One participant reports a whining sound from speakers and headphones when connected to a laptop, suggesting a possible issue with the laptop itself.
  • Another participant proposes that the sound may be due to grounding issues, recommending the use of an audio hum eliminator or a choke to eliminate 60 Hz powerline hum.
  • Suggestions include using shielded audio cables and minimizing RF interference from nearby devices like cellphones and wireless telephones.
  • A cost-effective solution mentioned involves wrapping the audio cable in aluminum foil to reduce interference.
  • One participant notes that laptops running on battery power should not have grounding issues, but suggests that audio adjustments from both Windows and the speakers may be conflicting, leading to a hum.
  • A later reply indicates that the Windows audio is set to maximum, and the hum persists even from the laptop's integrated speakers, implying the issue is not solely external.
Participants express differing views on the source of the hum, with some attributing it to grounding issues and others to audio settings or interference. The discussion remains unresolved regarding the exact cause and solution.
Participants mention various potential sources of interference and adjustments, but there are no consensus solutions or definitive conclusions about the underlying problem.
MrNathan
Hi, when i plug my speakers into my laptop, i can hear a slight whining sound from one of the speakers. i assumed it was the speakers, however i plugged some brand new headphones in, and the same problem occurred. this leaves me to believe it is a problem with the laptop. does anyone know why it is happening or how i can fix it?
thanks
Computer science news on Phys.org
I get a similar sound when I connect a radio modem next to the audio jack in the USB port. I think its the grounding cable that picks up the hum. You can either use audio hum eliminator, or try adding a choke, or a band-pass filter to eliminate the 60 Hz powerline hum. I would also recommend a thicker audio cable that is shielded from wifi and other radio frequencies, but obviously the easiest solution is to disconnect the usb cables and turn off wifi on your laptop to see if it fixes the problem. Also any other sources of RF interference around the speakers. Like cellphones, home wireless telephones, TV, etc.
Also a cheap man's solution is wrapping the aluminum foil around the audio cable and then wrapping that with electrical tape.
A laptop not plugged-in to an ac source does not have a proper ground.
But, that should not be a problem here, as laptops are designed to work very well with external speakers with the laptop running on it's own battery power.
Likely, this is the problem:
There are 2 competing general audio adjustments. One is from Windows itself, the second is from the speakers.
If the physical speaker audio adjustment is set too high, you will get a "hum"
Reduce that, and increase the Windows audio.
windows audio is at max.
and after checking carefully, i cans till hear the hum from the integrated speakers on the laptop. so its not an external problem. its just because the external speakers are louder.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 24 ·
