Solving E=MC2: What Does C2 Imply?
  • Thread starter TR14L
  • Tags
    E=mc2
In summary, JesseM is saying that velocity is just a direction in space time, and c2 has nothing to do with it moving faster than light.
TR14L
So, I understand the implications (basically, anyway) of solving the equation E=MC2 for E, and solving for M. But, what is the implied outcome of solving for C2? Just curious because the concept of C2 would imply faster-than-light velocity of something in my mind. Of course, my flawed thinking is why I'm asking in the first place :)
Thanks in advance.
Like any other equation, you can isolate any variable you wish in terms of the others. Think of C2 as just a parameter (a conversion factor)--it has nothing to do with anything moving faster than light.
Yeah, that was kind of the answer I was expecting. Just seemed odd to me that you could write it in that format.
Thanks for the speedy reply! :)
Note that c2 has the wrong units to be a speed anyway; in SI it has units of meters2/second2, whereas all speeds have units of meters/second (even faster-than-light speeds).
Good point, Jesse. Kind of a silly oversight on my part.
If you use arbitrary units then squaring things do nothing. If you use natural units where C is taken to be 1 then squaring it just gives 1 again, as it is now it is just a conversion factor between our arbitrarily chosen seconds and meters which should really have the same units. Velocity is just a direction in space time so it got no units.
No, natural units don't get rid of the fact that c is a constant with "dimension" different from a dimensionless constant like the ttp://en.wikipedia.org/wiki/Fine-structure_constant. Natural units are still a system of units just like SI, but they use units of distance and time where c happens to have a value of 1, like c=1 light-second/second, or c=1 Planck length/planck time (in planck units)
:confused:
Suppose you're going down the road at 100 km/h. Square it and you get 10000 km2/h2. That's not even a velocity. It doesn't have the right units. And even if it were a velocity, what's actually moving at that velocity?
No, if you define time to have the same dimension as the spatial ones then velocity is dimensionless. It is natural to have them equal since they translate into each other, separating them is just practical since that is intuitive to us but it doesn't really make sense considering the structure.
Velocity is just the projected angle in spacetime.
What Klockan3 is describing is the convention taken by geometrized units. What JesseM is describing is the convention taken by Planck units. Both systems are considered "natural".
Related to Solving E=MC2: What Does C2 Imply?
What does the equation E=MC2 mean?
The equation E=MC2 is a famous formula in physics, proposed by Albert Einstein in his theory of special relativity. It states that energy (E) is equal to mass (M) multiplied by the speed of light (C) squared.
What is the significance of C2 in the equation E=MC2?
C2, or the speed of light squared, is a constant value that is equal to approximately 9 x 10^16 meters per second squared. It is a crucial component of the equation as it shows that a small amount of mass can be converted into a large amount of energy.
Can E=MC2 be solved?
No, E=MC2 is not an equation that can be solved for a specific value. It is a fundamental relationship between energy, mass, and the speed of light that helps us understand the behavior of matter and energy in the universe.
Is E=MC2 only applicable to objects moving at the speed of light?
No, E=MC2 is applicable to all objects with mass, regardless of their speed. However, the equation shows that as an object approaches the speed of light, its energy and mass become more closely related.
What is the practical significance of E=MC2?
The equation E=MC2 has many practical applications, including the development of nuclear energy and nuclear weapons. It also helps us understand the relationship between mass and energy in fields such as astrophysics and particle physics.
12K
