Calc 2 Finding volume of wedge
The discussion revolves around finding the volume of a wedge using integration of vertical cross sections, specifically focusing on the geometric properties of a triangular cross-section defined by a sketch provided by the original poster.
  • The original poster attempts to define the base and height of the triangular cross-section using similar triangles and seeks assistance in determining the height function. Other participants question the definitions and dependencies of the height function, suggesting it may also depend on another variable.
Participants are actively engaging with the problem, with some providing checks on the original poster's approach and others seeking clarification on the numerical values from the sketch. There is a mix of interpretations regarding the definitions of the height and base functions, indicating a productive exploration of the problem.
There is a mention of the need for specific numerical values from the sketch, which some participants feel are necessary for further understanding. Additionally, the discussion hints at the importance of checking calculations to ensure correctness.
dorangospecie
Sketch: http://img88.imageshack.us/img88/6479/6219ek4.gif
Find the volume of the wedge in figure (A) in above sketch by integrating the area of vertical cross sections.
This is what I have so far:
b(x) = length of base of triangle at position x
h(x) = height of triangle at position x
For b(x) - use similar triangles
8/6 = (8-x)/b(x)
b(x)=3/4(8-x)
How then we would find the h(x) and solve the actual problem? Can anyone please help me out??
Note that height of the plane is also dependent on y
so should be h(x,y).
Find the plane equation. z = ax+by+c and so you know the height.
Can you please refer to the sketch and tell me the actual numbers used? I am really trying to figure it out, but I genuinely can't.
rootX said:
Note that height of the plane is also dependent on y.
I thought he was defining h(x) to be the height of the triangular cross-section -- not the height of the tetrahedron OABC over a point in the xy plane.
If we tell you the actual numbers used, then you won't learn how to figure things out, right? How does one normally go about trying to find the value of unknown quantities?
Of course, there's more than one way to solve a problem -- your apprach seems perfectly reasonable. Your formula for b(x) looks correct. I made a sanity check by plugging in two known values (x=0 and x=8) to see if it gives the right answer. (Did you remember to make that check?)
I'm confused as to why you aren't using the exact same method to find h(x).
  • · Replies 33 ·
