Calculate cangular momentum vector L
  • Thread starter Thread starter classicphysic
    Momentum Vector
To calculate the angular momentum vector L, the equation L = mv X r is used, where m represents mass. The user is unsure of the value of m and is advised to leave it as a variable in the final answer. There is a discussion about the timing of the post affecting response rates, suggesting that posting during peak hours could yield quicker assistance. Additionally, it's noted that the question may not belong in the "Advanced Physics" forum. Overall, the conversation emphasizes the importance of including mass in calculations and the need for appropriate forum engagement.
classicphysic
r = rr(hat) r=√(xsquared + y squared) r(hat) = <cosθ, sinθ>
v = r(dot)r(hat) + rθ(dot)θ
L = mv X r
I don't know m, how can i calcuate L? please help me
welcome to pf!
hi classicphysic! welcome to pf! :smile:
classicphysic said:
L = mv X r
yes, you do need m!
so just call it "m", and leave it in the answer :wink:
i am waiting for the help people...checking it every hour but no body answers it
tiny-tim answered you already!
What more do you need?
And I really don't think this counts as "Advanced Physics". So, wrong forum?
hi classicphysic! :smile:
posting it when the americans are about to go to bed, and the europeans are fast asleep :zzz:, isn't the best time, if you want a quick answer :wink:
(and posting it in the right forum would make it more likely that the right people see it)
btw, you don't need to keep checking … you should receive an email notification of each new post in any thread you've posted in :smile:
