Calculate Dynamic Mass & Force of Object in Motion
  • Thread starter Thread starter Padj01
    Dynamic
To calculate dynamic mass and forces for an object in motion, particularly a mass at the end of a string swung in an arc, one can use the equation F=ma, where F is force, m is mass, and a is acceleration. The tangential speed and the angle of the swing are crucial for determining the forces involved. The discussion clarifies that mass remains constant unless considering relativistic speeds, which is not applicable in this scenario. Understanding these principles allows for accurate calculations of the object's dynamics. Proper application of these concepts will lead to the desired results in analyzing the motion.
Padj01
I need to know how to calculate dynamic mass and forces. Example is a mass at the end of a string that is swung along an arc (not perpendicular or parallel to the floor). What equations or properties do I need to calculate dynamic mass and force of the object in motion? Thank you for your help.
Tangential speed. Angle that it is twirled at. From this, I see no reason why you coulde't solve for the rest.
Regards,
Nenad
Try f=ma.
I am not sure what you mean by dynamic mass. Mass is mass. Mass is only appreciably affected by its motion if you are talking about speeds close to the speed of light. It doesn't sound like you are.
AM
Thanks Andrew. That's what I was looking for.
