Calculate h if the fluid in the manometer is mercury
xCuzIcanx
A venture flow-meter can be designed as
shown in the figure. At position 1 the
velocity is 0.5 m/s, and pressure is 1.3 bar.
The cross section area at 1 is two times the
area at 2. The fluid inside the manometer
has a density ρ, and the fluid column has a
high h as shown in the figure.
Assume the temperature is 20oC,
conducting the following analysis:
1) Derive the equation h as a function
of ρ.
2) Calculate h if the fluid in the
Picture is attached.
To be honest, I have no idea what I'm suppose to do. Please help.
It's actually a 'venturi' flow meter.
Hint: apply Bernoulli's theorem to the flow.
So the flow meter would have the equation of the Bernoulli's Equation for fluids and the manometer would have the equation deltaP=rho*g*h. But how would I find the equation with those two separate one?
You need to use the Bernoulli equation to calculate the pressure difference between the two points in the flow. Then you need to use the hydrostatic equation to determine the difference in height in the manometer for the calculated pressure difference.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
