Calculate magnitude of the reactive force
  • Thread starter Thread starter shabs
    Force Magnitude
shabs
I just wanted to know how to calculate magnitude of the reactive force...The given values are for,mass,angle,distance,coefficient of kinetic friction and gravity..
Magnitude of what? Please ask a complete question.
