Calculate Rack Displacement for Rack & Pinion Steering
To calculate rack displacement for a rack and pinion steering system, it's essential to know the circular pitch of the gear and the number of teeth, as this will determine the travel of the rack per revolution. The design process requires either the specific gear details or the desired displacement along with the number of turns for accurate calculations. Assumptions about rack displacement should be based on the intended steering performance and mechanical constraints, rather than arbitrary values. Clear communication of the required inputs and outputs is crucial for effective design. Understanding these principles will guide the development of a functional rack and pinion system.
Reddy
Hii,
I am designing a rack and pinion steering system .I have strucked in finding 1)rack displacement,2)tie rod length.
The inputs that I have inner and outter wheel lock angles,turning radius,lock to lock turns,steering ratio. If I get rack displacement,I can get steering arm length.so how to find rack displacement. And I don't have any info about pinion and rack.
How to proceed to design rack and pinion?
I suggest you to take the circular pitch of thehttp://rover.ebay.com/rover/1/711-53200-19255-0/1?toolid=10029&campid=CAMPAIGNID&customid=CUSTOMID&catId=220&type=2&ext=191589449302&item=191589449302 gear then multiply it by the number of teeth which gives you the travel of the rack for one revolution of the gear. Beware of the units.If you have the travel you need, do it backwards to calculate the rack and pinion.
I guess that is it.
Thanks for reply,
I can't assume simply, ryt?there should be valuable reason behind assumption.on what basis I can assume if I suppose to assume rack displacement?
Reddy said:
Thanks for reply,
You either have to have the gear you want to use, or the displacement you need plus how many turns of the gear you want the total displacement to happen to calculate the pitch, then the gear. I'm not sure if I've made myself clear.
Likes billy_joule
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
