Calculate Spring Force on Car Impact Speed
The discussion revolves around calculating the speed of a car before it impacts a wall, given its mass, bumper spring constant, and compression distance. The car, weighing 4,600 kg, compresses its bumper, modeled as a spring with a force constant of 8.00 x 10^6 N/m, by 3.36 cm during the collision. The kinetic energy of the car is equated to the potential energy stored in the spring, leading to the formula v = √(kx²/m). The calculated speed before impact is 1.4 m/s, which some participants noted seemed low for a car. The conversation emphasizes that a higher speed would result in greater bumper compression, confirming the low speed of the collision.
charmedbeauty
To test the resiliency of its bumper during low-speed collisions, a 4 600-kg automobile is driven into a brick wall. The car's bumper behaves like a spring with a force constant 8.00 106 N/m and compresses 3.36 cm as the car is brought to rest. What was the speed of the car before impact, assuming no mechanical energy is transformed or transferred away during impact with the wall?
K.e=1/2mv2
p.e(spring)=U=1/2kx2
K=U
1/2mv2=1/2kx2
mv2=kx2
v=√(kx2)/m
= √(((0.0336)(1.12896*10-3))/4600)
v= 1.4 m/s is this correct it seemed a little slow for a car?
Looks good! Don't forget that if the car was going fast, the bumper would compress more than a mere 3 cm. Good thing it was going slow!
Thanks Phantom Jay.
