Calculate the charge on plate Capacitor
The discussion revolves around calculating the charge on capacitor plates using given capacitance values and charge inputs. The user correctly applies the formula Q = VC but struggles with the accuracy of their answers, particularly for the charge on plate R. Despite following the correct method, the computer marks their answer as incorrect, leading to frustration. Other participants confirm that the user's calculations are accurate, suggesting that the issue may lie in how the answer is submitted rather than the calculations themselves. Ultimately, the consensus is that the method is sound, and the user should check the formatting of their answer submission.
eutopia
this problem probably took me a whole hour :mad: but it seems like i don't know what I'm doing wrong...
diagram: http://loncapa.elps.k12.mi.us/cgi-bin/plot.gif?file=MaMargaret_elps_1115513252_23407965_plot.data&output=png
Capacitor MR=78.9 nF
Capacitor PL=38.3 nF
Capacitor TN=35.3 nF
Capacitor US=38.5 nF
Calculate the charge on plate S, if the charge on plate L is 6.51e-8 C. (right) Answer: 9.72e-8 C
Calculate the charge on plate R, if the charge on plate N is 7.29e-8 C.
(wrong) answer: 5.324771655e-8 C:
For the first part, I did
{Q} = {V}{C}
{Q} = 6.51e-8
{C} = [ 78.9/(78.9+38.3) ] times 38.3e-9 = 2.578e-8
{V} = Q/C = 2.5348
the second charge would then be: {Q} = (38.5e-9)(2.5348)
For the second part, I used the same process and got 5.324771655e-8 Columbs but it seems to be wrong, at least the computer says it's wrong, and I can't figure out what's wrong:
{Q} = 7.29e-8
{C} = 35.3e-9
{V} = (7.29e-8)/(35.5e-9) = 2.0651558
{V} = [ 38.3/(78.9+38.3) ] (2.0651558) = .6748760019
{C} = 78.9e-9
{Q} = 5.32477e-8
Your method is correct. But I get 5.34 e-8 C.:
Q/C = V
So V = 7.29e-8 /3.53 e-8 = 2.07 Volts.
C_{ML} = C_{MR}C_{PL}/(C_{PL}+C_{MR}) = 78.9 * 38.3/(78.9 + 38.3) = 2.58 e-8 (as you found)
So Q = VC = 2.07 x 2.58 e-8 C. = 5.34 e-8 C.
AM
i guess i just kept all the decimals in there... i'll check it again.
*Arg... it's still not right. If i round it becomes 5.34, if I don't it's 5.32
im so clueless...
Am I doing it right? If I am, then I'm leaving the problem and moving on. If I'm not, then I'll try some more; but I don't want to dwell on something that I absolutely can't figure out what's wrong with... and turns out nothing was wrong. If something WAS wrong then I wouldn't mind thinking about it more
please tell me I'm doing it right...
Eutopia: I already said your method was correct. That means you have it right.
AM
Your work looks fine. You said it was given as incorrect by the computer, so it is possible that the problem is in how you are entering the solution. Sometimes computer programs are rigid in how they want the solution entered, so even if it is a correct solution, if it isn't written the exact way it expects, the answer is marked incorrect.
