Calculate the clamping force to prevent the load from sliding
The discussion focuses on calculating the clamping force required to prevent a rubber clamp from slipping on a vertical steel pipe. The initial calculations suggest a clamping force of 333 N with a friction coefficient of 0.6, which is deemed sufficient to prevent sliding, albeit marginally. However, the importance of incorporating a safety factor, ranging from 2.0 to 10.0 depending on application criticality and environmental factors, is emphasized. Additionally, the effect of the load's moment and the potential impact of wet conditions on the rubber's friction are highlighted as critical considerations. A clear diagram is recommended to better assess the clamping scenario and its dynamics.
KavaKovala
TL;DR Summary
Clamping force
Dear,
Could you tell me if the calculations on the attachment are correct? I need to determine the force necessary to prevent the clamp from slipping.
Basically the clamp is a part of rubber that I can press against the pipe wall. A load will be attached to this part of rubber. The tube is vertical.
It's too simple to be true my calculations, lol
Thanks in advanced!
Clamp material: Rubber
Tube material: Steel
If I correctly understand, you have a clamp force of 333 N, a friction coefficient of 0.6, and a force perpendicular to the clamping force of 200 N. You are correct, it will (just barely) not slide. And it really is that simple.
However, any real world clamping problem requires a safety factor. Depending on how critical the application, presence of vibrations, how accurately you know the friction coefficient, and the consequences of sliding, a suitable safety factor could be anywhere from 2.0 to 10.0.
Likes berkeman and anorlunda
Hi jrmichler,
Thank you for your reply!
Just a doubt, Does the moment created by the load have any effect that must be considered?
I appreciate your help.
In order to answer your question, a diagram is needed that clearly shows what is being clamped to what, and how the clamping force is being applied. You need to show actual, rather than simplified, parts. And tell us what happens if it slips.
Keep in mind that, while you understand what you are trying to do, we have only your diagram and text to figure out what you are trying to do.
Water is a rubber lubricant. If the rubber gets wet, it may slide.
Check the coefficient of friction for wet rubber.
I assume in your diagram, the pipe is yellow. Is the rubber black ?
Is the blue band around the pipe a clamp, made from rubber or steel ?
What is the lighter blue ?
Hoop tension in a band around a pipe is not equal to surface pressure on the pipe.
Hoop tension is only doubled where both ends meet perpendicular to the clamped block.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
